It is currently Sun Oct 26, 2025 9:35 pm
 Post subject: 2g Tranny install!
PostPosted: Tue Apr 05, 2005 10:11 pm
I recentley acquired a 95 gst tranny and I need some info on the install. Whats needed? Thanks Geo!
PostPosted: Wed Apr 06, 2005 3:02 am
It depends on the clutch type. If you have a hydraulic clutch stock, it will work out straight. If you have a cable clutch, then you're in for a clutch swap as well. Maybe you'll need to modify the shift levers on the tranny. There is at least one thread about that, so you may do a search when stuck there. Other than that, it should be straight forward.
BTW, what engine do you have?
Got rabies?
PostPosted: Wed Apr 06, 2005 10:01 am
the tranny will work and it is hydraulic clutch, not cable
but I think you are going to run into a problem when it comes to mounting it up,
firstly the tranny mount will need to be changed and adapted I am assuming that you are putting this in a colt
secondly the splines are different I beleive that they are 25 or 27 or something like that so you might have to change your cups out to accomodate that on the axles
also make sure you use the correct motor plate, other wise your starter will not line up
good luck
w
Warren
PostPosted: Wed Apr 06, 2005 11:18 am
put the front diff from a 1g dsm tranny in it, and use all the stock mounts, should work just fine.
oh, and the speed sensor is different, no cable,
PostPosted: Wed Apr 06, 2005 4:40 pm
Im dropping it into a 4g63T swapped Colt GT. Oh how would I get the speedo working if there is no cable? Thanks Geo!
PostPosted: Thu Apr 07, 2005 12:22 pm
if i remember correctly, you can jsut unscrew the speed sensor and screw in the cable.
you might want to ask Jon ripple.
jon@teamrip.com
most of their built tranny's are 2g converted to 1g.
