It is currently Mon Oct 20, 2025 10:24 pm
Post new topic  Reply to topic  [ 22 posts ]  Go to page 1 2 Next
 Post subject: 4g15 Turbo
PostPosted: Tue Jun 01, 2004 2:18 pm
I finished my 1.5 turbo setup last week but I didnt have much drive time. One single race on the freeway with a first gen MR2 killed my rings. I smoked him(short lived). So yesterday I tore it apart and I'm going to install crome rings and possibly a thicker head gasket if I anyone knows where I can find one? It'll be back together in about a week or so and then I will bring my new setup to the rest of the 4G61t population. I will post picks and a full write. Also pics of my new 95 Subee Impreza bumper. later guys
2012 Explorer Limited
1989 Colt GT clone 4G63t auto
1992 Talon TSi
1990 Talon TSi
1995 Crown Vic
1993 Ford F-250 BBF
1987 Chevy Sprint Turbo
PostPosted: Tue Jun 01, 2004 3:56 pm
BANNED FOR FRAUD
Not bad. Were they the original rings?
Jason Veraldi
Scammer
PostPosted: Wed Jun 02, 2004 1:13 pm
Hey Stealthpony,
are you gonna rebore the piston holes or at least break the glaze?
PostPosted: Fri Jun 04, 2004 5:11 am
I've heard the 4G61T pistons fit the 4G15 w/ some machine work on the con rods and a little boring of the block... :wink:
Got rabies?
PostPosted: Sun Jun 06, 2004 9:05 pm
CSM O.G.
yep, they were the original rings. i took pisc of the carnage...actually broke the rings into pieces and snapped a ring-land off :twisted: pulled like a mofo though..and the only way i can describe the burnouut is that scene in The Fast And The Furious where Vince leaves the barbecue all pissed in the maxima and smokes the inside tire from reverse, only the 1.5t did it from a stop..hehehehe anyway, its gonna be a little while longer to get back together, since we now have access to a shop with a welder and stuff...rollcage!! later peeps
~joe
PostPosted: Mon Jun 07, 2004 12:09 am
Where is my turbo mani?????
how much you want for it???
01 Maxima VQ30DE
92 Summit 4g63t (Traded to Evo... R.I.P.)
I heard they ride mooses to work instead of driving cars. (About Canadians.)
PostPosted: Mon Jun 07, 2004 9:07 pm
CSM O.G.
oh, that... it was total sleeper, a subaru turbo, mounted on a flange after where the flexpipe used to be, BEHIND the motor, under the intake manifold.
from what a local soob dood said, the turbo only produces 6-9 psi, and the wastegate should be set around 7ish, so he figured it was a great turbo to use on a previously NA motor....ummm no. it still killed the pistons, but really, we didnt expect it to hold forever. we are currently looking down empty cylinders at the crank, and thinking, " what TURBO motors have pistons that will fit this with minimal boring? " does anyone have access to a victor reinz, or frienz, or whatever it is, the gasket catalog? or perhaps a clevite bearing book will have bore/stroke? anyone?
also, there is a 4.0 liter jeep exhaust mani on the floor of the shop, with some good mandrel bends in it, and my bro is an awesome welder, so a turbo manifold may be in the works...more to come. I will get a few pics of stealthpony's 95 soob bumper tomorrow, i promise.
PostPosted: Tue Jun 08, 2004 12:52 am
4g61t Delinquent
www.importperformanceparts.net has an engine kit with forged pistons for a 4g15 ;) with your choice of CR
I own a CSM.
PostPosted: Tue Jun 08, 2004 9:07 pm
CSM O.G.
on that site, it says that the c10 mirage turbo (g32b) pistons are 77mm, and the 4g15 is 75.5mm, so are the g32b pistons forged? what is the wristpin height? does anyone have a set lying around that they could donate to a good cause? or we could work a deal...i dunno, i think that if the 4g61 pistons supposedly fit then these would be easier...wow, i dint even find the forged 4g15 ones, but this gives me more to think about... thanks all
~joe
PostPosted: Tue Jun 08, 2004 11:25 pm
Nobody Important
I would love to turbo my jeep (or supercharge, or make it a stroker, or all of them :))
-paul
PostPosted: Wed Jun 09, 2004 11:12 am
Off topic but,
Paul if you need a 351W I got one lying around, I'm sure you wouldn't mind a little more bottom end!!!
PostPosted: Wed Jun 09, 2004 12:02 pm
Nobody Important
A what? (fyi: 2000 cherokee 4l)
PostPosted: Wed Jun 09, 2004 10:13 pm
351 Windsor small block, better than 302 Windsor but still 4 too many cylinders for most of us eh! :wink:
PostPosted: Wed Jun 09, 2004 10:50 pm
Off topic but,
I knew what you meant... ;)
In case there is anyone else interested, what year is the engine? EFI or carb?
Witty Signature Goes Here!
PostPosted: Thu Jun 10, 2004 8:09 am
Sorry for the further Klingon jacking of the thread ...
*no fart can's or DC headers will be harmed in the making off this post*
1978 351 Windsor 5.8L block - well seasoned Truck motor
- all rude edges ground down
- needs boring to .040" oversize
- crank needs .010" under on rod journals, 0.010" under on main journals
- have two front cover/fuel pump plates 1 for EFI 1 for carb fuel pump
- no intake/carb came with motor - but Ebay has tons of this stuff cheap!!!
- rods need checking (high mileage)
- pistons are scrap (still attached to rods/pins)
- harmonic dampener, couple pulleys, pwr string pump, 2 sets valve covers
1978 351 ..... head x2 - well seasoned 1.78" intake, 1.45" exhaust
- large CC comb. chamber head design for smog motor / heads decked can't remember
- tanked and magnafluxed - no rust - clean casting
- valves seats already cut for stock sized valves (box of spares not complete though...)
- intake has 1 angle cut - new seats all around (?)
- ports are excellent for 302 conversion, as yet unmolested ports and bowls!!
- stock screw in valve train studs - 3/8" - not included I didn't get them :-?
Anymore info can be provided upon request. Thanks for the question Kyle :D
