Sorry for the further Klingon jacking of the thread ...
*no fart can's or DC headers will be harmed in the making off this post*
1978 351 Windsor 5.8L block - well seasoned Truck motor
- all rude edges ground down
- needs boring to .040" oversize
- crank needs .010" under on rod journals, 0.010" under on main journals
- have two front cover/fuel pump plates 1 for EFI 1 for carb fuel pump
- no intake/carb came with motor - but Ebay has tons of this stuff cheap!!!
- rods need checking (high mileage)
- pistons are scrap (still attached to rods/pins)
- harmonic dampener, couple pulleys, pwr string pump, 2 sets valve covers
1978 351 ..... head x2 - well seasoned 1.78" intake, 1.45" exhaust
- large CC comb. chamber head design for smog motor / heads decked can't remember
- tanked and magnafluxed - no rust - clean casting
- valves seats already cut for stock sized valves (box of spares not complete though...)
- intake has 1 angle cut - new seats all around (?)
- ports are excellent for 302 conversion, as yet unmolested ports and bowls!!
- stock screw in valve train studs - 3/8" - not included I didn't get them
Anymore info can be provided upon request. Thanks for the question Kyle
