It is currently Thu Oct 30, 2025 6:21 pm
 Post subject: Suck @$$ 4g15
PostPosted: Wed Apr 07, 2004 10:08 pm
hey guys..... well it seems like one day the colt runs fine and i actually think the little 4g15 isnt that bad.... then like 2 days later my opinion changes completely..... sometimes i hate this car big time
well listen for starters today i was drifting on a dirt road and slide to the ditch and unseated my tire from my rim.... now tonight going down the road i notice that in 4th gear on my 4 spd tranny, my car wont accelerate any when i push the gas down further past 60..... it just seems to bog and slow down more.... what could cause this???? Honestly today the good ol gas can and a pack of matches theory really crossed my mind....
any help would be much appreciated
www.4g61t.org, My Anti-Drug
Member #486
1992 plymoth colt 1.5 4spd soon to have 1.8 parts and much more
1991 Eagle Talon TSi AWD eibach springs, kyb shocks, front strut bar, white face gauges, and a system
PostPosted: Wed Apr 07, 2004 10:29 pm
no wonder why your car is fruit and banana.... if you use it as a daily driver it will last a while..
but
sorry about your situation though..
PostPosted: Wed Apr 07, 2004 11:55 pm
is 4th the only place it does it? Where in the rev's are you? does it bog under full throttle, mid throttle, or both? Did you check for any obvious damage besides your tire? is it like fuel cut?
If you slam it real good, I suppose you could have kicked up some stuff in the gas tank, now the filter is clogged. Maybe it's a coincedence. Damage your exhaust? pinching off the power exit port??
Just a few ideas at this delerious hour. and a few questions to get us closer to the answer.
1989 Mirage Turbo 4g63T w/ small 16g just bolted in so far.
LSD, 1g flywheel/clutch.
1989 Colt GT 4g61T (63T build in progress)
1g ECU, Injectors, Exhaust manifold, 16g evo III Turbo, SMIC, and C Exhaust cam -9*
K&N Air filter, airbox cut up, MSD plug wires, NGKs, Apexi S-AFC II, MAF translator, tubular o2 housing w/ dump tube, Full 3" mandral.
Now I ran out of fuel!!
PostPosted: Thu Apr 08, 2004 7:18 am
well last night when it started bogging in 4th it was like mid and full throttle it just got worse with more gas..... i was around 2-3 grand i think somewhere in that range... but the car doesnt seem like its pulling like its supposed to... i just fixed the car the other day because i was having problems......... it has a new fuel filter and i dont think the exhaust is pinched anywhere....... maybe i should throw my gutted cat on, i hear sometimes the cat will make it do things like this???
Member #486
PostPosted: Thu Apr 08, 2004 8:20 am
Looks like a bad batch of gas that causes detonation under high load. Which in turn, causes the ECU to retard timing.
Er... do USDM 4G15s have a knock sensor? :-?
Got rabies?
PostPosted: Thu Apr 08, 2004 8:26 am
Nope...
PostPosted: Thu Apr 08, 2004 8:47 am
Oh OK then... :oops:
Got rabies?
PostPosted: Thu Apr 08, 2004 10:13 pm
Fuel pump could be culprit. I noticed a lack of poer under throttle and on the highway it didnt pull in higher gears like it should. You can do a test. Pull the top line from the filter(be sure to disable the distributor) hold your finger over the top of the filter and have someone crank the engine. This will give you a idea of your pressure. Mine would build like 5psi and then go to zero. With your finger off it should sqirt pretty good. Shouldnt just dribble. DONT SMOKE while doing this!!
04' Olds Alero
91' Colt GL hatchback
4g15 12valve 5spd.
Lots of little s#@t
PostPosted: Fri May 14, 2004 3:32 pm
hey man, might be your brakes from when you had that tire issue. remembering back to the days when my brakes were ceased, couldn't get over 80 then kept getting lower and lower. see if your brakes are good and warm after a few minutes of driving, might be that.[/img]
