It is currently Thu Oct 23, 2025 3:30 pm
Post new topic  Reply to topic  [ 351 posts ]  Go to page Previous 19 10 11 12 1324 Next
PostPosted: Tue Apr 30, 2013 7:08 pm
I could indeed use a good bumper! Mine is a Maaco-painted special that's green underneath...and currently flaking :(.
PostPosted: Wed May 01, 2013 8:49 pm
It's with great sorrow that I announce the passing of my in-dash clock :(
I have had many colts, and that clock was always a plus, when I found a working one. I've got to see if I can fix it, otherwise I'm going to mount my wideband there. It's an NGK one, with a rectangular display.
PostPosted: Thu May 02, 2013 6:48 am
I threw mine in the trash lol
PostPosted: Thu May 02, 2013 1:01 pm
My clock isn't dead! I managed to get it to work again, so life is good :).
Made a bit of progress today too...and yes, it drove out on it's own.
Got my wideband installed, so I was able to see what kind of AFRs I was getting on the fully untuned Evo 8 ecu swap. I have no idea what my fuel trims are, since I still haven't replaced the rad, so I didn't want to linger...but I was seeing a steady 14.5-14.7 :). Fired up right away too, I really like this ecu :).
My shocks are BLOOOOOOOOOOOWN, lol. On the 10' drive, it felt like a little whale. The paint I applied on the rockers actually matches up quite well too. It's close enough to not attract attention, which is all I wanted. I really need to find some skirts :(.
PostPosted: Fri May 03, 2013 12:25 am
I just read thru this whole build thread. Sick job man. Looks great!
PostPosted: Sun May 05, 2013 1:06 pm
Thanks :). The rust should have turned me away, but I'm a masochist that likes to learn about metalwork, lol.
Today I've managed to get the hood on, rad filled, timing set, and idle set. I still need to relocate my wideband 12v (I want it on during cranking, right now it is not), feed the WB into the ecu for logging, get a second fan (one fan is good-ish, but it is a bit too hot IMO), make the oil drain stop leaking, and get the car to HPAuto.ca for the finishing exhaust work. I hate making exhausts.
Basically, the car is going to sit for a few weeks while I sort out the VW Golf in the background. A guy has to make project money somehow ;).
PostPosted: Sun May 12, 2013 8:38 pm
...and let the delays begin again, lol.
My crank pulley wobbles like mad, so there's no way the car is moving until I replace it. I also need a second fan to help keep everything cool, it gets way too hot at idle.
Sigh...cars.
PostPosted: Tue May 14, 2013 12:14 am
ah well, at least they are the basic dsm/csm problems. could be worse! (crankwalk)
PostPosted: Wed May 15, 2013 8:57 pm
Yeah, definitely don't want that. I'll get a new pulley soon, right now it's back-burner.
Since I don't really have much to do for a while, I've begun the de-colting of my colt. I'm not going to rebadge it or anything, but I am dumping the monochromatic body color. I've always preferred the blacked out side trim/bumper strip/mirrors/grille of the mirage, and since my car has already been ruined with a Maaco paintjob (and HORRIBLY done at that), I figure what the heck :). The driver's side trim is drying currently, and removing it highlighted a really rusty area hidden under the trim (gee...rust on this car? I'm SHOCKED!). I might put a bit of effort into fixing it, but it's just surface rust, so I may just leave it. I hate bondo.
PostPosted: Sun May 19, 2013 5:09 pm
The new look.
I still have to do the rear bumper, but it's coming along nicely. It's not a great job, but hey...the car is rough, and I'm ok with that :).
PostPosted: Mon May 20, 2013 4:07 pm
Started on a little rad cover/shroud to keep all the air going where it belongs, since it's not a stock rad.
PostPosted: Tue May 21, 2013 2:43 pm
I've never been happy with my rad/IC setup, so it's getting scrapped. I'm going to go to a setup like I had before: civic battery (or relocated to the rear), and a Talon SMIC with ducting. I am a stickler for using OEM parts when possible, and I'm also bored, so might as well redo something :).
Now...I need to get a stock rad and fan, lol.
PostPosted: Tue May 21, 2013 7:28 pm
...aaaaand everything comes to a dead stop.
We've always had water in the basement, but today's torrential rain was the last straw. During the basement superflooding we came home to, I started kicking in drywall (very therapeutic :) ) and discovered that the mortar at the very bottom of my basement wall (hooray for cinderblock foundations from the 70s :() is crumbling. All car spending is now done, possibly for a while, until we can fix the issue.
Houses are worse than cars, sigh.
PostPosted: Tue May 21, 2013 9:10 pm
I sense a house on stilts!
There has to be a bright side to basement repairs!
Sorry, I tried man! :)
Well, we should see if there is a discount on ordering two rads!
P.S. If you still have the paperwork for PO buying the newer alum rad, I'll gladly bring it back to you!
PostPosted: Wed May 22, 2013 12:06 pm
Newer aluminum rad? No paperwork like that, but no worries...I've made some slight improvements that will allow a bit more efficiency out of the neon rad :). I dropped the IC about three inches, which gives the upper portion of the rad more access to cool air, and slid it slightly over so I can get a 7" pusher fan in as well. There's more room for the IC piping too, so this could be a win/win :).
I'm home today fixing the foundation damage, so I had some time to kill while waiting for the putty/patch to dry. Figured I'd work on the car a bit, to de-stress.
