It is currently Mon Nov 03, 2025 2:16 am
Post new topic  Reply to topic  [ 21 posts ]  Go to page Previous 1 2
PostPosted: Thu Mar 29, 2012 6:03 pm
Wish I could be helpful here....had the same problem, but I never tried test fitting a 1.5 control arm. I ended up using the Elantra control arms instead. With the Elantra control arms, everything bolts up like it should....plus the sway bar links are identical to the c53a 1.6 setup, so the same principal applies. You end up with a little negative camber in doing so.
How much negative camber?
1989 Mirage Turbo - 310whp - Sold
1998 Eagle Talon TSi AWD - Sold
2005 Legacy 2.5GT - Sold
1989 Dodge Colt GT
PostPosted: Thu Mar 29, 2012 6:24 pm
maybe 1 to 1.5 degrees
Good stuff - trucks bring it!
PostPosted: Thu Mar 29, 2012 8:22 pm
Same here, used the Elantra control arms. It was nice to have bolt in ball joints, and my alignment guy said it was np to set up.
PostPosted: Thu Mar 29, 2012 8:40 pm
Just found that Napa lists different part numbers between the 92-93 and 94-95 Elantras.
Rock Auto lists that they use the same control arm.
quickgt said that he is going to look up part numbers for me tomorrow. Does anybody else have any idea about which ones are correct?
1989 Dodge Colt GT
PostPosted: Thu Mar 29, 2012 10:00 pm
I speculate the earlier years are most correct, as the crossover point for electronics an such was 94.5 with the J1 Elantra.
PostPosted: Thu Mar 29, 2012 11:31 pm
Yes, 92-94.5 and don't use the 95, as Flying Eagle noted. Odd to hear they had different part numbers...just remember, the GL and GLS (sportier elantra) could be that difference, but I don't know personally.
