It is currently Mon Oct 27, 2025 4:00 am
PostPosted: Tue Apr 22, 2008 6:08 am
I was looking on ebay at springs for my friends stock 1990 Mirage hatchback and I found Megan Racing for approx. $140 US(including shipping) for the 3G Mirages and I also was looking on the Eibach Pro Series and Sportline Series for the 1G Eclipse AWD. I really wanted to know the main differences and if eventually sagging was the main difference in price and obviously brand name that has been proven.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 38826&rd=1
http://cgi.ebay.com/ebaymotors/Eibach-S ... dZViewItem
http://cgi.ebay.com/ebaymotors/EIBACH-P ... dZViewItem
PostPosted: Tue Apr 22, 2008 8:08 am
Any 1g lowering spring is probably going to be too low for a csm.
PostPosted: Tue Apr 22, 2008 8:19 am
If you check out my member page or Gallery section photos, (www.gallery.4g61t.org/Flying+Eagle) you can see that with stock struts and 1G FWD lowering springs that are a 1.6" drop on a DSM, prove to be much lower on a CSM, added to that is my shorter tires, so I sit pretty low. The rear is setup higher, but the front is pretty "foghat" looking - READ lowrider. 8) H&R springs and the code I believe is in my member posts, hopfeully with enough pictures to show the height. 205/50/15" Hercules G 3000v tires on JDM rims of some sort.
PostPosted: Tue Apr 22, 2008 11:52 am
So if I want to buy Eibach springs than I should go with a pair for a 2G GSX? I'm talking more about the Pro-kit springs, because they don't lower the car as much as the Sportline springs do. I thought most people on here run 1G aftermarket springs? So what is the best springs made to fit a 3G CSM?
PostPosted: Tue Apr 22, 2008 3:26 pm
Hey, I looked on your pics and I really don't think your car is near low. I have owned many cars that were very low but I had 1 in particular a 1998 Mitsubishi Eclipse GST and I dropped that on its belly(it was around 1.5-2 inches from the ground that is low).
