It is currently Sun Oct 26, 2025 12:42 pm
 Post subject: Fuel trims reset
PostPosted: Fri Nov 11, 2005 11:17 pm
Had something weird happen this week. Started the car one day and all the trims had reset to 100%. The car did not have power disconect since it had last run. ??????
PostPosted: Sat Nov 12, 2005 1:27 am
How are the CAPS inside the ECU case? My ECU was tripping the MPI recently so ..... I know it's not the same thing but it nevers hurts to check unless you know they are solid. Was your car hard cranking when it started up?
PostPosted: Sat Nov 12, 2005 10:48 am
Yeah, I was wondering about the ECU as well. Haven't looked at it for a year, but it was okay then. Can't say it cranked any more than usual. Guess I'll just wait and see if it happens again.
PostPosted: Sat Nov 12, 2005 10:50 am
I thought the voltage may have dropped below operating levels or the system "hiccuped" strange either way.
