It is currently Mon Oct 27, 2025 3:18 am
 Post subject: 4G15 a/c compressor
PostPosted: Fri Mar 05, 2004 6:37 am
Hello,
Should probably be in newbies' :oops: but need an answer ASAP;
I'm going to buy an a/c which was taken from 4G15 C50, in order to mount it to a non-ac car with 4G37 (becoming with 4G32BT).
Does the 4G15's compressor bolt onto 4G3x block? :-?
I'll arrange all the other stuff (condensor etc.) by means or another, but don't prefer to hack anything bizarre with the compressor block mounting, because I want to be 100% sure the belt will be moving exactly aligned&straight.
Thanks for any hints! :)
Mitsubishi Lancer AWD (C77A, 4G37) x 2
Mitsubishi Colt (C51A, 4G13) x2, 1 scrap & one slightly crashed
Mitsubishi Colt (C58A, 4G67), A basis for AWD mod...
A half of dozen of Subaru Justies (currently racing with one)
Volvo S70 TDI for daily use
PostPosted: Thu Apr 15, 2004 2:27 am
Anybody?
What about 4G15 a/c compressor onto 4G61? Any differences in mounting?
I'm about to have a full a/c set bought and shipped overseas, so I'd hate to see my money been wasted, if it doesn't fit to my engine..
Thanks in advance,
Arto
PostPosted: Thu Apr 15, 2004 3:22 am
4g61t Delinquent
Anybody?
Thanks in advance,
Arto
here stateside...most people take off the A/C to free up ponies :o
I own a CSM.
PostPosted: Thu Apr 15, 2004 1:22 pm
There was some discussion awhile... I think PMA talked about that. AFAIK, you will get this thing to work if the belts fit on all pulleys.
Got rabies?
 Post subject: compressor mounting
PostPosted: Thu Apr 15, 2004 1:34 pm
The A/C compressor mounts to a bracket that then bolts to the block. A 4G15 compressor mounts with 3 8 mm bolts to the bracket (probably 90 mm long?) and that bracket mounts to the 4G15, or 4G61 block with 4, 10mm bolts. Same bracket for 15 or 61 block.
Chris
PostPosted: Thu Apr 15, 2004 2:17 pm
is it also the same for the 2,0 cause i cant seem to get mine fixed
4g61t.com
