It is currently Mon Oct 27, 2025 10:52 am
 Post subject: GVR4 knuckles
PostPosted: Mon Mar 12, 2012 9:43 pm
So i've got a line on a way cheap set of gvr4 knuckles. I'm just wondering if anyone has some good info on the slotting the strut route to fix the positive camber. how much to slot and best way to do it? any help is appreciated.
 Post subject: Re: GVR4 knuckles
PostPosted: Mon Mar 12, 2012 10:21 pm
The best way? Pick up a set of camber plates from yoshifab. I'd stay away from cutting into the strut mount.
PostPosted: Mon Mar 12, 2012 10:32 pm
yes, those are a bit spendy for what I'm looking at now. I was under the impression you slot the bottom of the strut where it mounts to the knuckle allowing you push the whole strut in on the knuckle, kinda as cam bolts do but more extreme.
PostPosted: Mon Mar 12, 2012 10:49 pm
It's possible and I'm sure it's been done a lot by people who hack their cars but in the long run, it's not as safe as just buying camber plates. Cutting into the area where suspension points mount is never a good idea.
PostPosted: Tue Mar 13, 2012 7:48 am
http://www.4g61t.org/forum/viewtopic.php?f=6&t=32097 page 3. hack is a realitive term, like good, or cool. some consider anything not factory or direct bolt on to be a hack, reaming the tierod hole for the gvr4 knuckles so the colt tierod goes in normal is no less dangerous than slotting the top hole on the strut, some consider one a hack, some both, it is up to you to take care in what you do to make sure its safe. I plan to do both to my car.
PostPosted: Tue Mar 13, 2012 12:40 pm
I have another question related to the struts im using, im doing dsm struts front and rear, what is the best way to swap out the rear lower bushings, I just had it in the press at work but the bottom loop on the dsm strut started to split a little at the top. any one done this before with good luck?
