It is currently Mon Oct 27, 2025 7:12 am
PostPosted: Thu Mar 06, 2003 5:46 pm
Hi Guys!
I replaced the 3 caps, now my idle is oscilating between 1000 - 1800 RPMs after 15 minutes of driving. But when I restart the car, the idle stays at 700 RPMs.
Also, I have to turn the ignition key on and off 6 times and then crank the engine to start it because I still have the clicking noise.
My idle did not oscilate until I replaced the caps. What else could be affecting it? Did I wait too long to replace the caps (car has 36k miles)? Is my ECU unrepairable?
Thanks,
Ron
PostPosted: Thu Mar 06, 2003 5:48 pm
Sounds like its too late for that ECU... double check the soldiering job too make sure it got done perfectly...
PostPosted: Thu Mar 06, 2003 5:58 pm
Solder looks OK.
I did notice that the 47µF cap leaked alot and the copper pads underneath it was heavily oxidized and was turning black.
PostPosted: Thu Mar 06, 2003 7:04 pm
Sound definity too laste try takeing a bit of kerosine on q qtip and try and clean up that pad as much as you can that might save it...
