It is currently Mon Oct 27, 2025 9:53 am
PostPosted: Sat Apr 02, 2005 5:04 am
Hi Guys,
Am halfway thru timing belt change: have replaced both cam seals & crank seal.
However, the methods i've found for removing the oil pump sprocket involve wedging a screw driver against the silent shaft (which 4g63' have)to stop the pump from spinning.
4g61's dont have a balance shaft, so whats the best method to remove the nut on the oil pump sprocket in our case ?
Cheers
Gap
PostPosted: Sat Apr 02, 2005 10:33 am
Get your buddy to hold it and hit with an air gun with a alot of torque.
PostPosted: Sat Apr 02, 2005 6:22 pm
......no air gun in my camp :cry:
is there any other way ?
could i wrap a chain wrench around the sprocket, brace it and use a breaker bar on the nut......is much force required to loosen this nut ?
PostPosted: Sat Apr 02, 2005 11:55 pm
If there are bolt holes on the sprocket you can thread in bolts to use a long screwdriver/prybar to steady things while the ratchet pulls on the center bolt.
PostPosted: Sun Apr 03, 2005 12:59 am
Another way is to jack the car up on the drivers side, get a 6'' 1/2'' drive extension, position the rachet by the control arm and turn the engine over.
Make sure you disconnect your plugs and injectors.
Works like a charm.
PostPosted: Sun Apr 03, 2005 5:24 am
thx for the info, but there are no bolt holes in the oil pump sprocket.
also the breaker bar & turning the engine over works for the crank sprocket nut but not for the oil pump sprocket.
I ended up using a chain wrench (that I usually use to remove the sprocket on MTB). Wrapped the sprocket with rags to protect it. Using a breaker bar i was able to break it loose.
Cheers
Gap
PostPosted: Mon Apr 04, 2005 6:01 pm
I just use the old belt, rap it around and hold it tight.
89 Mighty Max 2.6. Lookin for side drafts 89 Colt turbo. SOLD
91 Galant GSX, waiting for 2.4
