It is currently Tue Oct 28, 2025 10:25 pm
 Post subject: 4g63 ecu
PostPosted: Sun May 01, 2005 9:34 pm
can the 4g63 ecu be used in a 4g67 engine.. recently swapped my engine to a 4g67.. the problem is that the ecu of the 4g67 is for m/t.. while the original 4g63 ecu is a/t (so is the tranny).. im experiencing abnormal shifting .. im thinking of just using the 4g63 ecu.. is this possible?
hope you could help me guys :D
PostPosted: Mon May 02, 2005 4:48 pm
plug one in and see what you get.
2000 Mirage RPW coupe. Too many mods.
PostPosted: Mon May 02, 2005 4:52 pm
Nobody Important
I thought the ECU had notihing to do with the tranny, there was a seperate brain for that.
I could be (and probably am) wrong though
-paul
PostPosted: Mon May 02, 2005 5:16 pm
yeah, auto tranny's have their own computer.
PostPosted: Tue May 03, 2005 8:59 am
4G63 and 4G67 ECUs do interchange. I think the 4G67 has the rev limiter a bit higher, though. :wink:
Got rabies?
PostPosted: Wed May 04, 2005 1:38 pm
Does it mean that the cables from a 4g67 fits the ECU from a 4g63?
Colt GTi 1,8L -90 (4G67)
http://www.soederman.se/colt
Don't worry there's an english version!
PostPosted: Fri May 06, 2005 2:09 am
Exactly. A 4G67 ECU will run a 4G63 and vice versa. :D
Got rabies?
