It is currently Thu Oct 30, 2025 2:02 am
Post new topic  Reply to topic  [ 28 posts ]  Go to page Previous 1 2
PostPosted: Thu Apr 28, 2005 12:34 am
the bottom line to me is this: there is no replacement for displacement, whether it be 4 cylinders or .4 liters.
.35 liters
90 GGSX
89 YX-600
92 Laser AWD
PostPosted: Thu Apr 28, 2005 1:45 am
If your gonna pick nits make sure you get it right.
The difference is exactly 402cc or 0.402 litres.
4G63 - 1997cc
4G61 - 1595cc
PostPosted: Thu Apr 28, 2005 6:19 pm
I find it is alot more then how much power it makes but what you want your engine to drive like.
If you like to rev the snot out of your engine go for the 1.6 cause it likes to rev and seems to have most of its pull in the higher rpm's.
If you like just raw tourque at a low rpm go for the 63. it will not like the high revs as much but it is a preference of where you want your power to be.
Also would all the extra tourque of the 63 make it that much harder to keep traction?
89 Mighty Max 2.6. Lookin for side drafts 89 Colt turbo. SOLD
91 Galant GSX, waiting for 2.4
PostPosted: Thu Apr 28, 2005 6:49 pm
4g61t Delinquent
The 1.6 pistons are actually weaker than the 2.0 stock for stock. The land rings are thinner and more prone to cracking if you get bad knock...but they are still stronger than most factory pistons.
i second that!
My 4g61t pistons
87 octane + turbo = bye bye piston
I own a CSM.
PostPosted: Thu Apr 28, 2005 10:13 pm
1595 cc's of fury
HAHAHA, that looks identical to my #2 cylinder. #3 had only broken a section off the top ring. I somehow got my base timing way off and didn't notice....maxing the knock count for a couple weeks, not good.
PostPosted: Fri Apr 29, 2005 4:04 pm
4g61t Delinquent
haha #1 & #4 seen better days in my car. but then again i bought the car off a moron.
ran nothing but 87, BCS was never hooked up, CAS was jacked up, one of the exh. valve heads in #2 was half MIA, valve cover was cracked. list goes on :(
I own a CSM.
PostPosted: Sat Apr 30, 2005 11:54 am
4G63 - 1997cc
4G61 - 1595cc
brainfart - i was thinking 2.0 to stroker size
90 GGSX
89 YX-600
92 Laser AWD
 Post subject: 4g61t vs 4g63t
PostPosted: Fri May 06, 2005 10:13 pm
i have a 4g61t in my race car w/ big turbo only 6psi of boost a 7500rpm i thing the 4g61t no have to much flow to move the turbo i go 4g63t i have a set JE pistons for sale to 4g61t .040 .866 pin in good condition and new pauter rods i you want
 Post subject: Re: 4g61t vs 4g63t
PostPosted: Sat May 07, 2005 12:16 am
What does this translate into? Are you trying to sell something?
89 Mirage turbo
92 laser awd
97 talon awd
08 Evo X
PostPosted: Sat May 07, 2005 12:29 am
Drew- LOL!!!! :lol:
PostPosted: Sat May 07, 2005 12:58 am
Engine 4G61T 4G63T
Horsepower 135@6,000RPM 190@6,000 55HP
Torque 141@3,000RPM 203@6,000 62T
Injectors 390CC 450CC 60CC
Turbo 11B 14B
Main differances besides size of motor and internals are 1.6 does not have balance shafts, and as for the 2.0 it gots even more edge stock for stock because it has a intercooler, larger injecters, larger turbo, larger intake manifold, larger exhaust manifold, and etc. Im sure you can make up the 55HP and 62 torque if you switch simple things which i have listed. But a person looking to get over 300+ horses on a daily driver should probbaly look towards a 2.0 rather then a 1.6
PostPosted: Sun May 08, 2005 9:29 am
300+ horses on a daily 61T is very possible I believe.....I'm shooting for 325whp in mine. yeah it will be a standalone computer car but still a daily. The 61 does have shorter ringlands but it also has an almost opitmal stroke which will make up for some of the drawback of the ringlands.
'90 CSM Hatch 4G61T swap....lots of goodies.
 Post subject: JE Pistons 4G61T
PostPosted: Sun May 08, 2005 11:23 am
JE Pistons to 4G61T .040 over $450 w/ rings i have pauter rods for sale $650
