It is currently Mon Oct 27, 2025 1:48 pm
PostPosted: Wed Apr 20, 2005 5:56 pm
Heres my updated list of what you will need to install a 14b/16g turbo, o2 and manifold on the 4g61t engine. Hope this helps someone
MD140476 WATER PIPE REAR
MD117764 WATER LINE FITTING
MF650114 X2 WATEPIPE BANJO/EYE
MF660065 X4 WATER CRUSH WASHER
MD140394 OIL FEED LINE
MF650102 OIL FEED LINE TOP EYEBOLT
MS650013 OIL FEED LINE BOTTOM EYEBOLT
MF660063 (2) OIL FEED LINE TOP CRUSH WASHERS
MF660064 (2) OIL FEED LINE BOTTOM CRUSH WASHERS
MD150523 OIL RETURN LINE
MR258477 (2) OIL RETURN LINE GASKETS
MD124675 TURBO/02 HOUSING GASKET
MD132931 TURBO RING GASKET
MD128901 TURBO FLAT GASKET
MD181032 TURBO MANIFOLD GASKET
PostPosted: Thu Apr 21, 2005 5:16 pm
CSM O.G.
would you be so kind as to label which of these parts can be sourced from a junkyard? like the oil lines.
thanks
~joe
PostPosted: Thu Apr 21, 2005 5:37 pm
thanks
~joe
Use new lines. They're relativley cheap and there's no chance that they wil have crap in them like ones you might find at the wreckers.
Geoff
2013 Genesis 5.0 RSPEC
88 Mazda Turbo II- LSX7
89 2.0 Turbo Colt
13 Ducati 1199 Panigale
PostPosted: Thu Apr 21, 2005 8:00 pm
^ ie the reason that the turbo blew and the guy couldn't fix it in the first place -=read=- coked oil lines to the turbo :o :wink:
PostPosted: Fri Apr 22, 2005 2:56 am
BANNED FOR FRAUD
thanks
~joe
Like everyone else was sort of saying, these are parts you want to buy new. You'd be defeating the purpose buy reusing used parts and potentially creating problems for yourself.
Jason Veraldi
Scammer
PostPosted: Sat Apr 23, 2005 5:40 pm
CSM O.G.
thanks, will do.
~joe
PostPosted: Thu Apr 28, 2005 6:10 am
anybody got an estimate on how much all those parts would cost??
and where to get them? dealer? auto parts?
PostPosted: Thu Apr 28, 2005 10:09 am
$161.21 if ordered online (walker's renton mitsubishi). If you plan on picking it up at your local mitsu dealer (ripoff) they will charge you well over $200.
PostPosted: Fri Apr 29, 2005 3:25 am
will all those gaskets and etc work with a 2G manifold??
obviously EVO3 16G would need diff gaskets right?
Users browsing this forum: colt200 and 8 guests
