Hey guys, been checking out the forum and have found it very useful, thanks! I just picked up a 91 colt last week for $200, and have been very pleasantly surprised with the driveability of the car, which has led me here because I now plan on keeping it.
This morning it got down below zero here in Montana, and for the first time the colt did not want to start. Normally, it starts right up with the first touch of the starter, although it probably hasn't been below 20-25 degrees out until now. I ran down the tank of gas that was in it when I got it, and filled it up and added some heet in case there was some water in the fuel. What would freeze up in my fuel system to cause it not to start? Would it be water in the lines? Is there anything I can do to prevent me from being late to work again?
Also, I just noticed yesterday, that the shift pattern on the knob only shows 4 gears, but I've been driving it like a five speed this whole time. Meaning there are 5 gears in it, so what tranny would be in there?
One more, I promise. My major qualm is the fact that there are no tunes in it. I've been trying to figure out the wiring to hook up a radio, but can't figure this thing out. I figured out the two power wires, white and green is the constant power, & I think it was black and blue is the other one. My question is: I have two red and black wires, and in the diagram I found, it says one goes to the front right, and the other is the back left; but when I put signal into the wire, both red and black would power the front right speaker. Also, what is the black and white wire? And I know everyone says the ground is behind dash, yadda yadda yadda, but where? Where the easiest place to ground it? Aaaahhh, it was driving me nuts last night in the subzero weather, outside trying to figure out this crazy wiring! Any help is hugely appreciated. Thanks
Quinn
