It is currently Sat Jun 15, 2024 2:14 pm
Post new topic  Reply to topic  [ 23 posts ]  Go to page Previous 1 2
PostPosted: Mon Sep 13, 2004 10:37 am
http://www.4g61t.com/forum/viewtopic.php?t=7557
PostPosted: Thu Sep 16, 2004 8:35 pm
can i just cap off the fitting where the line comes off of the intake to the pcv valve? i started on my own accumulator can today, is the pcv valve still used in this setup?
1987 Dodge colt premier 4 door g32bt running!!!! 3speed automatics suck!
PostPosted: Sat Sep 18, 2004 12:22 pm
You need the PCV valve. Don't take it off.
Got rabies?
PostPosted: Sun Sep 19, 2004 8:26 pm
ok, the vaccum line comming off of the intake to the pcv, can i plug that line and just have the line comming from the pcv valve to the catch can? im getting a bov and i need a vaccum sorce to hook it up to. i also need one to hook my boost gauge up to. could i hook both of these up to the same vac line?
PostPosted: Mon Sep 20, 2004 5:25 am
oh, and on taboospeedshop.com they say you can can get rid of the pcv valve, as long as you have a catch can, and all of the other vac lines on the valve cover are going to the can as well.
PostPosted: Mon Sep 20, 2004 8:22 am
The crankcase needs to breathe. You can route the PCV to the breather hose via a catch can. This is proven to work quite good.
I'd still hesitate to remove the PVC.
Got rabies?
PostPosted: Mon Sep 20, 2004 3:28 pm
wont it breathe just with an open line going to the catch? im not saying i want to plug off the line, i just want to do away with the pvc by removing its internals.
PostPosted: Fri Sep 24, 2004 10:45 am
Now I get it. :D Shure you can remove that damn thing. Just make sure you have a catch can to route the breather hose and the PCV hose to.. That's it. 8)
Got rabies?
