It is currently Fri Jun 07, 2024 2:17 pm
Post new topic  Reply to topic  [ 130 posts ]  Go to page Previous 1 2 3 4 59 Next
PostPosted: Thu Apr 15, 2004 2:05 am
so on the ECU side we have pin 1 for DATA pin 10 for DIAG and pin 12 for GND so i just splice into the wire for pin 12 with 10?? cause on the LAPTOP side there are only 2 wires.....(yes im slow... it's not my fault i was raised un moronville errrrrrr.....mormanville;) )
1983 Honda VF750F
1986 Chevrolet C-10 305
1990 Eagle Summit ES 4g63na 5spd
1990 Chevrolet Corvette L98
1996 GMC Suburban 454
1999 Volvo S70 AWD L.P.T
PostPosted: Thu Apr 15, 2004 2:07 am
4g61t Delinquent
:lol: FINALLY THE TRUTH COMES OUT!!!!!!!!!!! :lol:
I own a CSM.
PostPosted: Thu Apr 15, 2004 5:50 pm
I would say yes - To put the ecu into logging mode you connect those two wires you mentioned.
Member #31
PostPosted: Wed May 19, 2004 8:09 pm
How do all you guys know how to make the cable just from looking at the schematic? My friends and I all looked at it and we have no clue what the means. I wan't to make a cable for my 91 talon. Aslo I thought there were supposed to be three wires in the cable?
Thanks,
Brian
PostPosted: Wed May 19, 2004 9:45 pm
There are three wires at the datalogger end, ony two at the palm end as one of the wires splices into two... making three wires.
Member #31
PostPosted: Thu May 20, 2004 9:49 pm
Does anyone have a pic of the whole cable and a close up on the ends for a palm?
PostPosted: Fri May 21, 2004 1:24 am
There's nothing in it to photo really, tx, rx and gnd... the circuit diagram says it all...
PostPosted: Fri May 21, 2004 8:43 am
This is a simplified picture of my datalogger calbe, hope it will help you
Swap
Begin: September 16 2005
End: October 7 2005
Rebuilt
Begin: April 16 2006
End:June 1st 2006
But still not running
PostPosted: Sun May 23, 2004 4:04 pm
Hey guys thanks for all your help I got it working. :D I figured out what my problem was I am using pocketlogger software and with that you have to switch pins 2&3 then it will work. Now if i could just get it to work with my sony clie that would be nice. I have been testing it with a friends palm because I know it works. Anyone useing this cable with a sony clie? I think I am going to try and make my own serial cable and see if that will make it work.
PostPosted: Sun May 23, 2004 9:54 pm
There is a list of compatible devices on the mmcd stie (or teh pocket logger site if you are using pocket logger software)
It depends on what palm os the pda uses.
Mike
Member #31
PostPosted: Sun May 23, 2004 10:17 pm
Will it be a problem if the cable is connect to the ECU permanently?
Swap
End: October 7 2005
Rebuilt
End:June 1st 2006
PostPosted: Mon May 24, 2004 4:48 am
Nope - but if you are adjusting timing - you have to disconnect it.
Member #31
PostPosted: Mon Jun 14, 2004 6:58 pm
alright...finally got everything soldered up (pretty positive i wired it right) and the palm doesn't get any readings. it behaves just like when i run mmcd w/o it plugged in. is it supposed to beep like when i hotsync to my computer? any suggestions on what might be wrong?
thanks...
1g smic, 2.5" turboback, 1g exhaust cam, abs intake, 13g turbo, mbc, vdo boost gauge, greddy egt
PostPosted: Tue Jun 15, 2004 3:53 am
Have you started logging? Start up mmcd, open a new log and unpause...
Member #31
PostPosted: Tue Jun 15, 2004 4:06 am
yep. did that.
car's running. unpaused (selected sensor's flashing down in the bottom left). just no data coming in.
the switching diode has to go in a certain way, right (ie: it can't go backwards)? mine has the little band on the side farther from the palm (if that makes sense)...is that wrong?
please and thanks guys.
