It is currently Fri Oct 31, 2025 6:31 pm
Post new topic  Reply to topic  [ 18 posts ]  Go to page Previous 1 2
PostPosted: Fri May 14, 2004 4:55 pm
well i can get some high temp agsket material from my old ladys job... try that out to see what happens?see if blocking it off helps any?
http://www.clubgp.com/newforum/upfiles/ ... d93156.gif
PostPosted: Sat May 15, 2004 6:21 am
You could try it. 8) But be careful, if you mess up, you may ruin your engine (i.e. sucking in broken gasket material, flooding your engine w/ water from the TB heating etc.).
If you get it to work, you da man! And please don't forget to write a VFAQ on it. :D
Got rabies?
PostPosted: Tue May 18, 2004 5:12 pm
well i have the coolant lines discconnected.. so now all i have to do is she what makes the isc work.. guessing i shhould dissasemble it and take a good look at it and see what i can come up with..i also needget off myy ass and hook up this safc but would rather do it withthe car idleing properly.. do youhink the afc would fix this problem?
Users browsing this forum: No registered users and 33 guests
