It is currently Wed Oct 29, 2025 3:20 am
PostPosted: Thu May 06, 2004 9:59 pm
2 months ago i replaced the ECU on my Colt and it fixed the problem right up... suck part is that now it seems to have happened again... i need to know what to look for as to why my ECU is dead again.... any and all ideas welcome...
Thanx
As you slide down the Banister of life,
may the splinters never point the wrong way. :)
PostPosted: Thu May 06, 2004 10:09 pm
get a good rebiult one
the factory ones have a defect
RX-7 Fanatic
PostPosted: Thu May 06, 2004 10:59 pm
But after only 2 months... it cant be that bad of a defect...
would this be a problem if i parkedthe car and it wouldnt turn on again after 2 hours?
got spark... got engine turn... just no boom
PostPosted: Thu May 06, 2004 11:56 pm
Yeah that happens, I went through 3 of them over the course of a summer.
PostPosted: Fri May 07, 2004 12:41 am
It might be the caps. Those commonly go bad. You might want to replace those. It's pretty inexpensive.
PostPosted: Fri May 07, 2004 4:28 am
Why not? all these ECUs are the same age 12+ years old yes its definetly the caps every ECU has faulty caps its not a matter if they die its when they die... fix the caps fixes the problem...
PostPosted: Fri May 07, 2004 7:18 am
Banned for being a dick
I will not dispute the cap issue, had it happen to me twice. Another thing that might be frying the ECU is the ISC. If your car has a bad idle and you do not replace the ISC then yes this can fry the ECU.
PostPosted: Fri May 07, 2004 2:40 pm
Ok dumb question... but whats an ISC?
PostPosted: Sat May 08, 2004 8:37 am
Idle Speed Control.
Got rabies?
