It is currently Wed Jun 05, 2024 1:50 pm
Post new topic  Reply to topic  [ 50 posts ]  Go to page 1 2 3 4 Next
PostPosted: Wed Nov 19, 2003 2:58 pm
FYI:
Swapping turbo cams in NA for more power & other cam info.
Seems like one should be getting 92-94 cams only.
Also, please read this.
Got rabies?
PostPosted: Wed Nov 19, 2003 7:57 pm
I've heard these cams give buckets of bottom end but really lack up top. (mostly because the turbo is on and at that point who really cares) this mod may give good results for the auto crossers but not for everyone....
PostPosted: Thu Nov 20, 2003 12:11 pm
It looks like it is useful for people who use their NA cars as daily drivers and sometimes as race cars. Gotta find out in how far emmissions are affected.
Got rabies?
PostPosted: Thu Nov 20, 2003 8:40 pm
I was wondering about cams...
I plan on swapping a 4g63 N/A and now have another mod to try since i can get cams for free at work. :wink:
Also, is it true that the 4g61t has the balance shafts already eliminated? and the parts can be transfered to the 4g63?
04' Olds Alero
91' Colt GL hatchback
4g15 12valve 5spd.
Lots of little s#@t
PostPosted: Fri Nov 21, 2003 8:41 am
soc: yup thats true
PostPosted: Sun Feb 29, 2004 6:54 pm
BANNED FOR FRAUD
Yup, all balance shaft removal kits contain stock 4G61 parts.
Jason Veraldi
Scammer
PostPosted: Sun Feb 29, 2004 10:13 pm
HEHEHE! I tore down the blown 4g61t at work and removed the plug and took the whole oil pump and front cover! Pretty simple kit. I wondered what the piece that goes into the pump looked like. :D :wink: How many horses can realistically be expected on a N/A 4g63 with shafts removed?
04' Olds Alero
4g15 12valve 5spd.
Lots of little s#@t
PostPosted: Mon Mar 01, 2004 7:08 am
I've been told about 10hp whats that worth I dunno...
PostPosted: Mon Mar 01, 2004 7:30 am
...which is about 5%. How much do theese weight?
Edit: Let's do some simple math. The German 4G61 NA has 124 HP, the 4G63 NA 150 HP. 124/1.6*2.0=155 HP. While this may be as well due to the shorter stroke of the 61, it seems like 5 HP is gained by the balance shaft removal. 8)
Got rabies?
PostPosted: Mon Mar 01, 2004 9:34 am
5hp for a mod that wont cost me anything, i can live with that. As they say on monster garage, FREEEEEBIE!
04' Olds Alero
4g15 12valve 5spd.
Lots of little s#@t
PostPosted: Tue May 18, 2004 7:19 pm
the link at the top of the page is broke
did anyone happen to save the info that it contained???
i REALLY want to know, i MUST make my car go faster!
thanks
Zac
I am Dyslexic of Borg, You will be Ass Laminated
(\_/)
(O.o)
(> <) This is Bunny, Copy Bunny into your signature to help in his quest for worldwide domination!
PostPosted: Sat Jun 12, 2004 1:28 am
Anyone has the original 1991 JDM 4g61T cam timing? Is it the same as the 1992 model?
PostPosted: Tue Jan 18, 2005 11:40 am
Newbie here. The link above is broken. Does anybody have info if there are any actual gains if I put 4G63Turbo cams into my 4G67? And if so, do I need both intake and exhaust cams? Thanks.
PostPosted: Sat Jan 22, 2005 8:49 am
I don't know if that info is saved anwhere else. :-? You need only to swap the exhaust cam, as the intake cams are alike.
Got rabies?
PostPosted: Sun Jan 23, 2005 12:58 am
Thanks. Anybody tried the HKS cams in their 4G67's?
My Ride
