It is currently Tue Oct 28, 2025 5:24 pm
 Post subject: engine fuel cut on 4g63
PostPosted: Sat Nov 15, 2003 9:07 pm
I did a 4g63 swap on a non turbo colt. it seem like the engine fuel cut at 5 or 6k rpm. the engine sounds like detonating or popping. please give me some idea on what's wrong with the car.
PostPosted: Sat Nov 15, 2003 9:17 pm
we will need more specifics, like..
exactly when it happens, temperature, only warmed up?
PostPosted: Sat Nov 15, 2003 10:18 pm
Nobody Important
Which turbo are you running?
Intercooled? If so, which kind and where it is mounted
New fuel filter?
Which fuel pump do you have?
What octane gas are you using?
How old is the gas?
Have you recently switched octane grades?
Do you have a pocketlogger? Knock sensor? Any other diagnostic tools?
-paul
PostPosted: Sun Nov 16, 2003 4:53 am
Plug wires, ecu caps, boost leak. Bla,Bla,Bla.
PostPosted: Sun Nov 16, 2003 4:56 am
couldnt he have a failing fuel pump that he didnt notice b4 because he had a 1.5?, just a thought
4g61t.com
PostPosted: Sun Nov 16, 2003 6:09 pm
Could be something as simple as plugs and leads
www.4G93T.net | www.4G61NZ.co.nz | www.SquidInc.co.nz | <RR>
PostPosted: Sun Nov 16, 2003 10:00 pm
read the post dudes.
4g63=non turbo[/b]
PostPosted: Mon Nov 17, 2003 10:38 pm
High RPM misses are likely three things and I would check them in this order:
Problem: Incorrectly gapped plugs/Incorrect plugs or wires
Solution: NGK BPR-7ES gapped @ ~.028, Magnecore 8.5mm wires
Problem: Not enough fuel/Lean condition
Solution: You should already have the proper instrumentation -- O2's should be over .88v and EGT's under 870C in upper revs.
Problem: Fuel-cut due to ECU seeing too much airflow
Solution 1: Hack the MAS (least favorable)
Solution 2: Add an AFC to fool the ECU's airflow readings and raise the fuel-cut ceiling.
Solution 3: Adapt a 2G MAS to raise the fuel-cut ceiling
Solution 3: Add a GM MAF translator, TRE MASC, or other fuel control (GReddy E-manage, AEM ECU) to eliminate fuel cut completely (most favorable).
HTH,
Bill
Bill T.
'95 Eclipse GS-T (sold)
'95 Talon Tsi AWD (RIP)
'89 Mirage 4G15 (sold)
'89 Colt GT Turbo (sold)
'92 Galant VR-4 #753 of 1000 (sold)
'99 Eclipse Spyder GSX
