It is currently Tue Jun 04, 2024 6:05 am
Post new topic  Reply to topic  [ 97 posts ]  Go to page Previous 13 4 5 6 7
PostPosted: Fri Apr 08, 2016 6:12 pm
I ordered some superpro bushings from this site:
http://www.moog-suspension-parts.com/
Just search your bushing spf... and it popped up for mine 1500 and 1160 aswell as 1706. We will see if and when they arrive
94 Mitsubishi Mirage "4dr"
PostPosted: Sun Mar 26, 2017 6:25 pm
I put in an order with https://www.energysuspensionparts.com/ ( they are not energy suspension but they carry their products ), and we will see if the listing showing that they had the parts in stock was accurate or not. I asked for a call before shipping anything if they could not do it in one batch order.
I ordered the following for my C53a, using C53a control arms and their matching rear style mount:
SPF1160K Front lower control arm inner front (press in halves - no outer casing)
SPF2026k Double offset front lower control arm inner rear - GSR turbo style fitment X1 bag (contains two bushings, one for each side)(cased bushing designed at press into factory mount, mount is removable with two large bolts and one large nut)
SPF0427K Rear panhard bar bushing X2 bags (each bag does one end of the double ended bar)(no outer casing lots of grease required to press/ squeeze into place)
I already have 20mm Elantra/turbo sway bar frame to bar bushings in place, and the turbo control arms do not require stabilizer link bushings as they are double ball and socket style.
PostPosted: Sun Nov 10, 2019 8:44 pm
can someone please clarify for me what is needed for my setup?
I have an original 89 gt turbo, yoshifab camber plates, koni yellows, I would like to order all bushings available. please and thank you.
also, anyone have any suggestions when using the yoshifab camber plates?
White 89 colt GT Turbo
tuxedo 91 1GA TSI auto
Silver 91 previa
Silver 2006 G35 6spd Sport sedan F.S.
PostPosted: Sun Nov 10, 2019 10:53 pm
I did up up a post a while back that should spell it out nicely.
Follow what I ordered in my post above and then substitute a non caster change bushing set for the front LCA as the one I mention is increased caster on both front arms rearward positions. The front LCA bushings on the turbo cars have a rear bushing that is also used in Evo1+ Applications.
PostPosted: Sun Nov 10, 2019 10:54 pm
Quote from the first page, that still works.
So, I visited the link above as my curiosity for what parts cost, while having time to think about the car during the offseason, has piqued.
Went into their price listing:
SPF-1141K, SPF-1142K and SPF-1142AK are all various versions of the non-turbo/non-GSR rear control arm bushings.
NON-TURBO CONTROL ARMS
$74.00 US SPF 1140 K HYUNDAI LANTRA 1600CC FR LWR I - standard caster
$74.00 US SPF 1141 K FR LWR CTRL ARM INNER REAR BUSH - Increases passenger side caster and leaves the drivers side standard - ORDER 1 PER CAR (TWO BUSH PER BAG)
$75.00 US SPF 1142 K FR LWR CTRL ARM INNER REAR BUSH - Increases passenger side caster and decreases drivers side caster - ORDER 1 PER CAR (TWO BUSH PER BAG)
$75.00 US SPF 1142 AK FR LWR CTRL ARM INNER REAR BUSH - Increases caster on both sides - ORDER 1 PER CAR (TWO BUSH PER BAG)
$54.00 US SPF 1160 K FR LWR CTRL ARM INNER FRONT BUSH - ORDER 1 PER CAR (TWO BUSHINGS = 4 pieces, AND TWO SLEEVES PER BAG)
If you want to play with different rear bushings on a turbo/GSR car, then you want to use these part #s:
TURBO CONTROL ARMS
$158.00 US SPF 1714 K FR LWR CTRL ARM INNER R BUSH - "0" OFFSET CHANGE, STANDARD OFFSET - ORDER 1 PER CAR (TWO BUSH PER BAG)
$178.00 US SPF 2025 K FR LWR CTRL ARM INNER REAR BUSH - "+1" OFFSET CHANGE, SINGLE OFFSET - ORDER 1 PER CAR (TWO BUSH PER BAG)
$162.00 US SPF 2026 K FR LWR CTRL ARM INNER REAR BUSH - "+2" OFFSET CHANGE, DOUBLE OFFSET - ORDER 1 PER CAR (TWO BUSH PER BAG)
$54.00 US SPF 1160 K FR LWR CTRL ARM INNER FRONT BUSH - ORDER 1 PER CAR (TWO BUSH = 4 pieces, AND TWO SLEEVES PER BAG)
These are the FWD Panhard Rod bushings, regardless of turbo or non-turbo:
$29.00 US SPF 0427 K HYUNDAI/TOYOTA PANHARD ROD - THIS IS THE PANHARD ROD BUSHING SET FOR C50/C60 FWD CHASSIS CARS, ORDER 2 PER CAR - BECAUSE IT CONTAINS ONE SLEEVE, 1 BUSHING PER BAG (EACH BAG DOES 1/2 OF THE PANHARD BAR)
Turbo models and Elantra sway bars use a different link and do not require bushings for the end links.
These are the base model sway bar bushings for the links:
$22.00 US SPF 2092 BK / SPF 2092B-4K (OLD #) UNIVERSAL LINK PIN BUSH - C52A/C62A BASE MODEL SWAY BAR LINK BUSHINGS, ORDER 1 PER CAR - CONTAINS 4 BUSHINGS TO SANDWICH THE BAR ENDS
Turbo/Elantra/GSR Sway Bar to Chassis bushings are as follows:
$23.00 US SPF1875-20K - Lists as Hyundai front sway bar to chassis. - ORDER 1 PER CAR - CONTAINS 2 SPLIT BUSHING PAIRS TO SANDWICH THE BAR
PostPosted: Mon Jun 28, 2021 10:49 am
I have 2 more sets of the SPF1142AK's left in stock in FL for $59.48 + Shipping
PostPosted: Mon Aug 02, 2021 7:00 pm
It might be best to introduce yourself and the business or where exactly you are selling these kits from.
Not as many people come to the sites these days, but we like to vet the user and sellers as they become members here, all the same.
Cheers,
Tim
