It is currently Mon Oct 20, 2025 2:09 am
PostPosted: Mon Feb 04, 2019 3:00 pm
Hello,
I sold my 91 Colt and many of the parts for it but still have the following available:
I am a RockAuto clearance junkie, I purchased many spare parts for it over the years (many of them are Beck/Arnley)
Pistons and rings (standard and oversize)
Connecting rod and crank bearings (standard and undersize)
12 Cylinder head valves (both intake and exhaust)
Valve seats
Block and cylinder gaskets and gasket kits
Valve cover gasket
Oil pump
Various coolant hoses
Motor mount
Calipers and ventilated rotors for a 4-door
Turn-signal headlight combination switch
OEM Mitsubishi control arm bushings
Over the years I have amassed the following parts from local salvage yards:
Many spare ECU/ECM's
Distributors
Seatbelt control box and wiring harnesses, including door latch microswitches
Spare F5M21 transmission (bearings noisy)
Set of mounted winter tires (P175/65R14 on universal wheels)
Loose steel rims (13 and 14 inch)
Several loose tires
2 steering knuckles with hubs, bearings and brake rotors
2 steering knuckles with hubs, bearings and ventilated brake rotors from a 4-door Summit.
Washer fluid reservoir with pump
Rear wiper motor and wiper arm
I'll post photos and actual part numbers as soon as I get a chance.
Please let me know if you are interested or need any parts.
