Offline |
The Silent Administrator |
Wires that keep the car from starting are a signal to the ECU, and wires that go to your dash ares strictly a visual type of function and don't impede the car starting. That said, if you have loose wiring that impedes the car starting (and probably causes running issues too), then you need to get the wiring diagnosed and any affected wires replaced, and or terminals changed unless there is a bigger issue in the sensor/distributor.
