It is currently Tue Jun 04, 2024 4:23 am
 Post subject: F4A22 vs W4A32
PostPosted: Thu Jan 25, 2018 12:25 am
What is the difference between these transmissions and does anyone know which vehicles that can be found in?
 Post subject: Re: F4A22 vs W4A32
PostPosted: Thu Jan 25, 2018 12:51 am
Fwd auto trans vs awd auto trans. They are found in many mitsubishi vehicles. Seriously many...
PostPosted: Thu Jan 25, 2018 9:54 pm
f=fwd..w=awd..
now if you meant the diff between w4a32 and 33.. the 33 is a dsm trans..and made for turbo motors.. the 32 is a expo van trans.. not meant for big power.. also the converter and flexplate are diff.. the 32 uses a 3 bolt plate/converter setup while the 33 uses a 4 bolt setup.
PostPosted: Sat Jan 27, 2018 1:35 am
f=fwd..w=awd..
Thanks. Any idea if the pan from W4A32 is the same as any of the others? It's a 14 bolt pan.
PostPosted: Sat Jan 27, 2018 12:25 pm
im pretty sure the pan is the same.. I know the end clutches are. (for the awds)
what are you working with? fwd or awd... year also.
