It is currently Mon Jun 03, 2024 7:39 pm
Post new topic  Reply to topic  [ 51 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Fri Apr 19, 2013 11:55 am
It looks like that line and end pictured is a solid fitting.
Yes, solid fitting on the fuel sending unit.
PostPosted: Fri Apr 19, 2013 1:12 pm
Ok that might be the problem with limited ability to tighten. The only place I'm using this fitting is with a floating/loose fitting on a flared fuel line.
PostPosted: Fri Apr 19, 2013 7:46 pm
Take a look at the "lip and hole diameter".
PostPosted: Sat Apr 20, 2013 4:54 pm
Hi Guillaume.
I'm not sure about the sealing capacity with this fitting !
Take your time and after reflection, take the good fitting for your fuel lines :wink:
PostPosted: Sat Apr 20, 2013 8:13 pm
Salut Rémy,
I feel exactly the same as you. Safety first ! You know what they said ; Buy cheap, buy twice ! Shame on me... ;)
PostPosted: Tue Apr 23, 2013 12:34 pm
Parts : 29$
$hipping : 27$ ](*,)
Now I remember why I tried the blue fitting ...
PostPosted: Sat May 25, 2013 9:41 am
Little updates, I put informations here for members who want to do the same (start AN lines from OEM fuel sender init).
The 3sx fitting (14x1.5 to -3AN) fit very well (very closer OEM line).
If I had to buy another fitting for the same application, I think I will try the Earls 9894DBHERL (Like LittleEvo have previously written). It will probably be cheaper than 3sx fitting...
Picture 1 : From left side ; OEM fitting , blue fitting from e-bay , from cie torques (Bosch Regulator Swivel Adapter) , and finally the 3sx fitting. Take attention to the hole diameter ; the blue fitting is too big and wont seal properly (I guess..).
Picture 2 : upper left : OEM fitting (hose) , upper right : blue e-bay fitting , lower 3sx fitting
3sx fitting :
PostPosted: Sat May 25, 2013 1:58 pm
Extremepsi sell the good fitting adaptor now : http://www.extremepsi.com/store/product ... 559&page=1
I have drilled to the stock inner hard fuel line size this fitting at home with a drill column, easy and no flow restriction...
Thanks for pics Guillaume :D
PostPosted: Wed May 29, 2013 3:08 am
I thought the inner diameter looked a little small on that fitting.
PostPosted: Sun Jul 21, 2013 8:43 pm
I'm going to pegasus racing tomorrow for those fuel fittings. Anyone still need them?
PostPosted: Mon Jul 22, 2013 12:33 am
Nah, I ended up using the Earls non flared been working good so far.
PostPosted: Mon Jul 22, 2013 12:26 pm
Great. I have a shitload of these now. Hope someone can use them.
viewtopic.php?f=66&t=37962
PostPosted: Tue Jan 16, 2018 10:57 pm
Anybody know of a fitting with an 8an thread?
PostPosted: Tue Jan 16, 2018 11:04 pm
they make these now.. just need to make sure u drill in the correct spot to make sure it clears everything.. I drilled where the metal comes up and then had to get a new hanger cause it didnt fit..... best way is to cut it off as flush as possible then file or grind it flat.. center punch then drill the new hole. they have -6 and -8.. i got both for mine.. https://www.extremepsi.com/store/produc ... ctid=31855
PostPosted: Tue Jan 16, 2018 11:51 pm
Wow I was just looking into this method... I'm curious about the clearance from the tank to the underbody... Will an 8an 90 degree bend fit between the tank and car?
