It is currently Wed May 22, 2024 11:28 pm
 Post subject: Fuel pump assembly
PostPosted: Thu Aug 31, 2017 10:20 pm
Any ideas where I can find a new , or at least a clean fuel pump assembly for the 89 CSM hatchback?
Non turbo and turbo models must share the same gas tank and fuel assembly. Am I wrong? But I also assume the tanks and assembly are different between the sedan and hatchback.
My other thoughts are to size up a DSM assembly and modify it to suit.
DRCOLT
1989 3g Colt GT turbo w/4g63t
 Post subject: Re: Fuel pump assembly
PostPosted: Thu Sep 07, 2017 1:03 pm
I should have one laying around somewhere.. I'll dig a bit and see what I can find
1990 Colt AWD 8.8
PostPosted: Sat Sep 09, 2017 9:00 pm
Keep me posted.
DRCOLT
PostPosted: Mon Sep 11, 2017 7:27 am
Found this in the scrap pile.. not sure if its colt or 1g
1990 Colt AWD 8.8
PostPosted: Fri Sep 15, 2017 6:20 pm
That might be a Colt assembly. What happened with the fuel feed line? Is that modified, or broken?
DRCOLT
PostPosted: Fri Sep 15, 2017 9:13 pm
Compare to the fuel pickup assembly in my build thread. I compared an 89 turbo pickup and later model 4g15 pre-93. Look for gas tank restoration photos and you will be within one or two pages of where the pickup assembly photos lie.
The one pictured above would have been modified to allow for AN pass thru fitting to be used. They have a pair of nylon sandwich washers between the threaded/nut portions.
PostPosted: Sat Sep 16, 2017 11:55 am
Ok that sounds right, this was most likely the one that was in my 90 hatch before i went to a fuel cell. it had a bulkhead fitting in it.. 6 or 8an to hose barb inside the tank. if you want the hanger just throw me $20 and ill ship it out on monday.
shit just saw you were in canadadadada. well whatever is the cheapest shipping option to you. if you could cover that you can have it.
1990 Colt AWD 8.8
