It is currently Mon Jun 03, 2024 10:37 pm
Post new topic  Reply to topic  [ 206 posts ]  Go to page Previous 19 10 11 12 13 14 Next
PostPosted: Tue Dec 06, 2016 1:12 am
Defi gauges are the best
PostPosted: Tue Dec 06, 2016 12:24 pm
Stepping motor gauges, I like!
Super clean installation, glad to see that was an option and not in a super inaccessible location.
PostPosted: Thu Dec 08, 2016 9:01 pm
My new turbo kit in the works. I picked up a t25 exhaust housing off ebay a few months ago for pretty cheap. less than a 100. the more I looked at it the more I liked how easy it would be to make the internally gated housing work. With my tig welder not working so great I was really just not in the mood to finish up the other turbo setup which requires some pretty technical welding to finish. so I switched gears to this internal gate setup. some initial pics. time to remove turbo for further fitments.
Imageimgurl
Imageimgurl
Imageimgurl
PostPosted: Sat Dec 10, 2016 2:19 am
I love it. I really want to figure out a way to mate up a 7670 with a T3 IWG housing to the FP cast manifold. Do you think it's possible?
PostPosted: Sat Dec 10, 2016 10:55 am
it can be done. there are pics in this thread of t3 3071 done in a similar way. the 7670 has a pretty large frame though. might be some fitment challenges to deal with. I may be cutting the vband off on this setup. then welding downpipe directly. this will allow for smoother radius turn. downside would be housing can long longer be swapped for 7163 with same footprint
PostPosted: Mon Dec 12, 2016 10:21 pm
progress as of today. took a while to get pipe crushed just right. I took my time. pretty much decided to cut the ex housing and weld directly to it the first bend. waiting on vband clamps that I ordered today. so likely wont be much progress till they get here.
Imagepost a picture
Imagepost a picture
Imagepost a picture
Imagepost a picture
Imagepost a picture
Imagepost a picture
PostPosted: Tue Dec 13, 2016 6:58 pm
takes big ones to cut housing on new turbo. did some waste gate porting and port matching. important to me to think ahead and make car as easy to service as possible. I really like how this is coming out. easy to get in and out of bay.
Imageupload gambar
Imageupload gambar
PostPosted: Tue Dec 27, 2016 6:56 pm
had to take a few days off. had my "summit build accident" installed a 6in cutting wheel on a 4in tool. wheel exploded on me.
Imagepost images
Imagepost images
exhaust building is nothing short of kicking my butt. mostly because I am not that great of a fabricator. my builds function very well and I can say I built it, in the end thats what matters to me. never used vbands on an exhaust before. the first one I welded on and found the flanges warped like crazy. struggled with making it seat for several hours. in the end guessed it wasnt worth the risk. so I cut that weld off and added more pipe before trying another flange. only that one warped as well. gonna proceed with the exhaust build and come back to figure out how to make it seal. turbo kit just needs a bracket made for wastegate. it still slides in and out without having to remove fans. so pretty happy with it. got an old muffler cut open for some custom re-packing. this will fit nicely in the cat position.
Imagepost images
Imagepost images
Imagepost images
PostPosted: Tue Dec 27, 2016 10:08 pm
Creepin' me out with that laceration! Dagnabit that must of hurt.
Keep safe and keep doing what you are doing!
Maybe Tig is a must when welding those flanges because they are rather tempermental with excessive heat? Or you have to go really slow when using other methods? Nobody likes a bunch of start and stops when you just want to find a rhythm and keep going.
PostPosted: Tue Dec 27, 2016 10:26 pm
ouch! sorry about your injury.
i bet keeping those flanges straight is a pain. i imagine you tried clamping the two halves together as well while welding? could help a little but probably not enough.
you might also try a larger heatsink. if you had a thick flat chunk of steel (1/2-1" thick). Then after tacking the flange to the tube maybe you could clamp the flange face to the chunk of steel. its amazing how much heat a clamped on heatsink will remove, the flat surface will also help to keep things flat too.
i worked i a metal shop the last 10 years and we had lots of thick chunks of scrap like that you could ask around the local fab shops.
PostPosted: Wed Dec 28, 2016 8:33 pm
Damn dude, that's a gnarly cut! Glad you're ok.
Is that a T-25 housing, or T3?
PostPosted: Wed Dec 28, 2016 10:54 pm
Yeah I feel extremely fortunate it wasnt any worse. half of the blade just missed my face. wake up call to be more careful. the housing is t25 inlet. finished the turbo kit up today. I could start it now open downpipe. but i think i will wait till the first muffler is in place.
Imagefree image host
PostPosted: Thu Dec 29, 2016 1:03 am
You must be getting excited, thing is gonna rip now
PostPosted: Thu Dec 29, 2016 5:27 pm
getting nervous actually. a lot of work and no one has actually used this turbo on a dsm 4g63. got muffler sealed up. weighs a little over 6lbs. should be a quiet muffler for its size and weight. I think muffler manufactures fall short of how well mufflers could work. mostly because you never get to see whats comes on the inside. so they skimp on nice noise absorbing internals. gonna make a similar muffler for the space in front of tank. trying a side exit on the driver side first. hopefully it will be quiet enough to suit my needs. the original exhaust and turbo weighed 99lbs. the efr turbo assembly weighs about 8lbs less. hope to save another 30 on the exhaust setup.
Imageupload photos
Imageuploading images
Imageadult photo hosting
and although I have spent a lot of time on this kit I simply cannot imagine being disappointed. to reassure myself I periodically look around the net for dyno results. here are some I found today. cobalt ss forum:
"Black 2010 SS/TC "Luci(fer)" | Purpose built for road track |ZFR 6758 | Fully bolted | Built internals | Built & ported Stage 3 head| Cryo treated Powell 4.45 | Tune by Term2 & ECaulk | 479whp/471wtq on e47 @ 26psi "
PostPosted: Sat Dec 31, 2016 7:22 pm
so jumping out of my skin now. turbo kit is installed. downpipe done. started engine with just centre muffler propped on a stool. not welded yet. was shocked at how well it works. very quiet. then added second muffler on the ground. stupid quiet is the best way to describe it. I am stoked now. side exit exhaust will be a reality.
Imageforum image hosting
