It is currently Sun Oct 19, 2025 6:55 am
PostPosted: Tue Mar 29, 2016 4:08 pm
so ive been researching and seen alot of posts saying this head on my block would net about 11:1 comp... if this is correct would that be fine to run N/A? i dont want to boost this van just give it more umphhhh...
any pro's/con"s/info would help alot.
I know i need to change the cam gears and use a galant 2.4 dohc t-belt.
thanks
PostPosted: Tue Dec 20, 2016 9:37 pm
I did this swap on my talon circle track car. I just used the stock n/a ECU. It was way faster than anything else so I never tuned it. I figure it had 160hp with the same tq or more. I doubt you will regret doing the swap, besides running premium. I bet you could even turbo it (5 psi) or go e85 and turn up the boost.
