It is currently Tue Oct 21, 2025 7:30 am
PostPosted: Wed Jan 27, 2016 3:54 am
So, basically, I have the opportunity to grab the full drive line from a 93 but thought I'd ask a quick question.
Any differences in the system from a 93 to 92 (aside from the difference in transmission mounts ) that would preclude me from using any of the pieces?
My 92 transmission has to come out and I figured I could drop in the 93 trans. but I also have a rusty spring perch in the rear so I began considering an entire driveline swap.
Any thoughts?
PostPosted: Wed Jan 27, 2016 12:08 pm
only differences are where roll stop mounts are.
5spds appear to have early engine style roll stops for 92. 93 up have roll stops on trans.
autos are all late stlye with roll stops on trans.
there are also differences between 1.8 and 2.4 engine setups. the full drivetrain should work if engines are same
PostPosted: Wed Jan 27, 2016 1:10 pm
Yep, both are 2.4 automatics. Should be good to go. Cheers.
