It is currently Mon Jun 03, 2024 3:07 pm
Post new topic  Reply to topic  [ 37 posts ]  Go to page Previous 1 2 3
PostPosted: Sat Dec 26, 2015 8:40 pm
IS your car FWD? That would explain the lift in the back. I put these struts in and it lowered but mainly because of the cobb Springs which I do not know the drop rate. My car is AWD so alot heavier in the back. Will post pics soon after the install.
For the record:
This is how my Colt sits with the Evo X GSR Rears:
Not a big fan of lowered cars so I don't really like if it looks taller, also I just found a set of stock MR eibach springs so I may be replacing the stock GSRs for these...
92 Eclipse GSX (Dead)
89 Colt GT (AWD Swap) H1C
88 Cummins Suburban
69 Cutlass convertible
PostPosted: Sun Dec 27, 2015 6:33 pm
OK guys, I was finally able to finish up the EVO X rear struts on my AWD Colt. Now you probably wont have the same results because When I ordered these struts they came with COBB drop springs that I do not know the drop rate of. Cobb only has 2 drp rates for these springs either 1 5/16" or 1 3/8". Im assuming I have the 1 3/8" that have settled. Overall the before and after measurements resulted in a 1 5/8" drop total. Keep in Mind that my car is AWD so this will be different for FWD. Also to start out with, I had CSM struts with a welded on DSM bushing so my struts were extra tall. I think it has a nice rake to it now.
Before
After
88 Cummins Suburban
PostPosted: Sun Dec 27, 2015 7:01 pm
that looks awesome Mo.... when u launch there is enough room so it shouldnt rub... I get my alignments done at jack furriers down the street from motorsport.. they did mine a few times when I changed out parts.. since the last time ive put about 5k miles on the tires and no sign of any wear.. and no torque steer either.
PostPosted: Sun Dec 27, 2015 7:41 pm
Thanks Steve. I dont think I should drive it that far yet. So Im gonna find something closeby. I was thinking of slotting the front struts before I go.
88 Cummins Suburban
PostPosted: Sun Dec 27, 2015 11:59 pm
i forgot where u moved to.. cause there is also a great place out by estuned.. just stay on old vail rd I think it is..go past there place and its about a mile or so past there on the left..cant remember the name but can look it up if u want it.
PostPosted: Tue Jun 28, 2016 1:12 pm
Anyone else try this out? I'm thinking about jumping on this wagon soon.
PostPosted: Thu Jul 14, 2016 11:15 am
So what's the story for the fronts? How involved is it to make them work?
How much heavier are the AWD Hatch in the back? The rears might be perfect for my FWD Sedan!
