It is currently Mon Oct 20, 2025 4:22 pm
Post new topic  Reply to topic  [ 33 posts ]  Go to page Previous 1 2 3
PostPosted: Thu Nov 12, 2015 7:08 pm
greedy type test fine to 35psi. nice used ones still go for up to 200 on ebay. and I like them because the valve stays open during early spool. allows turbo to spool faster than normal BOV. I been using them for 12 years now and still like them.
this setup makes 400tq at 3700rpm in a loadless light 2500lb car with loadless 3.9 rear end. the type S works VERY well.
PostPosted: Fri Nov 13, 2015 4:39 am
I believe it, this greddy is one of the old school type s, I got it used few years ago and still working great so far
your car is like a 10 all around. this one was a 3. it was disheartening to see.
Thanks for that 10, I still have to improve some details on it, like the driver side fender has some dents, remove those gay low profile tires hehe and the rear upper control arms need to be replaced, also I would like to install a 97-98 front bumper ;)
PostPosted: Fri Nov 13, 2015 4:53 am
That Greddy is garbage. A boost leak test might surprise you.
Everything that I install is garbage for you Steven, even if they work well, like my Ebay Godspeed turbo and the Ebay blow off valve on my Colt, as long she's functional, I boost leak tested my car up to 35 psi and it never leaked, I know the bov may not last as we wish but hey 427whp @25psi on ebay stuff and reliable? I know that power may not impress you, she is a DD either way, I rather build something to last than build something to be fast once...
