It is currently Wed May 22, 2024 9:27 pm
PostPosted: Fri Oct 30, 2015 3:45 pm
With all these "new car" threads popping up, I figured I should show my new purchase. I have been looking for a new DD for more than a few months now, but couldn't get on board with anything newer than 2000. I was a little reluctant to buy a DSM for a daily, but the car, along with the price I was offered, was too good to pass up.
I went to high school with the previous owner, as well as found him the car to buy 10 years ago to replace his '95 Eclipse RS. It hasn't been driven in about 4 years because he broke something in the trans. Should be an easy fix for me though. Hasn't seen a winter since 2006, and has no real rust to speak of. Car has tasteful mods and all maintenance is up to date. He works at a local NAPA so any time there was a sign of something wearing out he replaced it immediately. My plans are to change the wheel and tire setup, change the stereo/gauges/turbo timer for more factory-looking stuff, and a few other upgrades. After that I just want to drive and enjoy the car. Car is currently in storage along with my Colt until spring time when all that nasty salt is washed off the roads. Below is a copy and paste of the current mod list.
- Motor -
Motor and head are pretty much stock 2gb
Bottom end was been rebuilt with new factory pistons, rings and bearings
all new timing components
stock 2g head with valve job at time of rebuild
revised 2g lifters
RRE Oil catch can
HKS 272 cams and adjustable cam gears
Evo 3 Intake manifold
1150 FIC injectors with unnamed fuel rail on E85 fuel
Walbro 255 fuel pump with rewire relay kit (for constant 12v)
Megasquirt 2 standalone fuel management system
zetronix wideband o2 sensor tied into megasquirt
- Random -
Stuart Warner Boost gauge, shift light, and EGT gauge (not currently hooked up, never wanted to tap the T3 manifold)
DDM Tuning 9006 HID retrofit kit
HKS Turbo Timer custom mounted in dash (not working with megasquirt)
Aftermarket radio/cd player
100% Full interior, nothing was ever removed
- Bolt ons -
ETS 7" tall street intercooler kit with short route ic pipes all powercoated black
Tial 50mm BOV with 12" vac spring not recirculated
Borg Warner S256 ETT with PTP turbo blanket
Turbonetics T3 manifold
Turbonetics Evolution Wastegate with open dump o2 housing
custom 3" exhaust turbo back with no cat/resonator
4" custom turbo inlet with replaceable filter
- Drivetrain -
95 TRE Stage 1.5 built trans with taller 5th gear (currently broken will detail below)
95 Transfer case
ACT 2600lb full street disk
Fidanza lightweight flywheel with newer surface disk
stock axles and diff
B&M short throw shifter - also still have stock shifter
energy suspension motor/trans mounts
- Suspension/brakes -
Tokico illumina 5 way adjustable shocks
H&R sport lowering springs
Motegi DP10 17" rims with Toyo Proxie 4 tires
Crossdrilled and slotted front rotors with premium ceramics all around
- Fluids -
Engine - 10w40 Royal Purple
Trans - Redline MT90
Rear Diff - 75w90 Royal Purple
PostPosted: Fri Oct 30, 2015 4:12 pm
love the color man.. and super clean looking car.. gratz on getting it.
PostPosted: Fri Oct 30, 2015 8:26 pm
Love it man!
PostPosted: Fri Oct 30, 2015 8:36 pm
Oil it to keep the strut tower rust from becoming the crazy neighbor next door, that you just can't get rid of!
Looks really really clean though.
PostPosted: Fri Oct 30, 2015 9:45 pm
Get rid of those wheels ASAP!
PostPosted: Fri Oct 30, 2015 11:02 pm
Way ahead of you. Picked up a set of dubs for it because, well, I'm a ricer. 18x8.5 5zigen FN01R-C's with some Potenza RE-01's in 245/40/18. Should fit nicely over the Evo Brembos I have planned for it.
PostPosted: Sun Nov 01, 2015 9:34 pm
I don't hate those wheels, but I'd definitely take the 5Zigen over them. Congrats on the pickup, those are my favorite 2g body style!
PostPosted: Tue Dec 01, 2015 3:01 pm
Awesome I have a 95 awd talon the same color, best looking color for a 2g talon ;)
