It is currently Tue Oct 21, 2025 10:33 pm
Post new topic  Reply to topic  [ 47 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Fri Aug 22, 2003 8:20 am
Okay, you're probably right then.
Damn, I'm confusing everything with anything at the moment! Cordias with Starions, 1G and 2G, 420A and 4G63....
I'm sorry for any inconveniences caused by this.
Got rabies?
PostPosted: Fri Aug 22, 2003 1:32 pm
Basically, the engines are the same - just the mounts that are different. Correct or not?
As far as I've read, it's generally agreed that the engine components (internals) in the VR4 engine are stronger than the Evo 1/2/3 equivalent anyway.
Just a shame we don't get ANYTHING with the earlier engine in it over here - we've never had Galant VR4s, Evos (import only till recent models) or DSMs here at all. :-(
PostPosted: Fri Aug 22, 2003 10:45 pm
BANNED FOR FRAUD
Well, if you want to get into the nitty gritty with the differences, they're two very different motors. The mounts aren't the only differences. Any gearhead or techno geek with intimate knowledge could go on for pages as far as the exact differences. But no need for that. They're similar, but different enough that they're not easily interchangeable.
As far as the GVR-4's being stronger than the Evo, I can't say for sure. I'd say it's a toss up with a slight advantage in the Evo's favor in my opinion. I just know they have stonger internals, where as the GVR-4 were just more run of the mill parts.
Jason Veraldi
Scammer
PostPosted: Mon Sep 22, 2008 1:08 am
lets get back to the subject 6-speed 4g63
where there is a will there's a way!!!!!!!!!!
now the basics
4g63 fwd f5m22
4g63 awd w5m33
6g72 fwd f5m22
6g72 awd :
- 5sp w5mg1
- 6sp w6mg1
all these trannies have similar gearbox housings
but the clutch housing are different, from clutch housing to gearbox bolt pattern looks identical
things to consider
the input shaft has 25 splines and what does the have 4g63?
the rear end on the 6-speed has a different gear ratio than all the 5speeds models.(3.307) or (43gear/13pinion teeth count) this is for the 6sp
good luck finding a rear end and tranny $$$
i would love complete this swap or at see it done for more info on the these 3000gt trannys and detailed pics refer to
http://www.stealth316.com/2-awd2.htm#Transaxle
this swap is possible! i believe, if this has been helpful let me know if this is a swap that anyone is attempting let me know and plz post pics :lol:
PostPosted: Mon Sep 22, 2008 10:58 am
Try again. The AWD 3Si boxes were made by Getrag. So, not compatiable.
Only the F5M33 used on the NA fwd is similiar with the exception of the engine side case section.
It's not going to work, unless you get an adapter made.
PostPosted: Mon Sep 22, 2008 2:17 pm
yup ur rite, listen to the to words: SIMILAR not the same, and LOOKS identical..looks meanin looks the sam but not sure. so please dont kill every1s dream of a 6sp 4g63. if you any info on please let us know wat will have to be done... but answer me how many splines are on a 4g63 input shaft "18 iam guessing"?
PostPosted: Mon Sep 22, 2008 2:19 pm
dang soo as of now it looks like no 6 speed?
PostPosted: Mon Sep 22, 2008 2:34 pm
i know theres a way if can u need to go my link i posted 1st and read it then think about what you say...
PostPosted: Mon Sep 22, 2008 2:37 pm
also go here 4 reference
http://www.3si.org/files/3S_AWD_trans_s ... manual.pdf
PostPosted: Mon Sep 22, 2008 2:38 pm
was that post to me or the other guy?
PostPosted: Mon Sep 22, 2008 2:39 pm
and does any have a 4g63 awd tranny service manual so we can all compare? that post was to other guy
PostPosted: Mon Sep 22, 2008 2:40 pm
and you lol
PostPosted: Tue Sep 23, 2008 1:47 pm
I'm just being realistic.
Using your logic, Ford and GM transmissions look similar. Looks like I can swap parts between the two. See the illogic?
If was as easy as swapping internal parts, Shep, TRE or Jack would have done it by now.
PostPosted: Tue Sep 23, 2008 4:00 pm
yeah. but has any ever tranny to put the two trannies together to at least see what they could come up with?
PostPosted: Tue Sep 23, 2008 5:09 pm
Who made the tranny is irrelevent, the size of the gears and how they fit is all that matters.
