It is currently Mon Oct 27, 2025 2:43 am
 Post subject: Plugs and wires
PostPosted: Wed Aug 20, 2003 9:05 am
Could you guys tell me what plug and wire that is decent for 4g61?
Sonny F. Walukow
1999 Toyota RAV4
1990 Honda Accord
1989 Colt GT (Sold)
PostPosted: Wed Aug 20, 2003 10:19 am
The standard wire will work fo sure. But try Magnecor wires if you want to. I have no experiences with them, though, but everyone recommends them so I guess they're good. :wink: I've heard they cost less than the original wires.
As for spark plugs, I use Beru Ultra-X in my 4G15 and also used them in my now dead 4G67 :cry: . The engine runs a bit better and smoother, but I couldn't notice any difference in mileage or power output. In case you don't know 'em (no one seems to use them here except me), Ultra X plugs have 4 ground electrodes.
BTW, I use them on a NA car. I don't know how they behave on a turbo car.
Got rabies?
PostPosted: Wed Aug 20, 2003 3:12 pm
ngk bpr7-es
copper core plugs, do not ude a platinum tip plug
PostPosted: Wed Aug 20, 2003 5:08 pm
Denso IRIDIUM :D
Member 209
89 Colt GT RIP
92 Mirage 4dr
91 Celica
http://members.sounddomain.com/gage1
http://community.webshots.com/user/miragegt
PostPosted: Wed Aug 20, 2003 7:44 pm
I use bpr6es plugs - and magnecore wires kvr8 ones...
They work fine in my car - with plugs get cheap ones and just change them regularly... wit hte leads - it doesnt seem any different to me - but they supposedly last longer so thats what I bought them for!
What do you guys gap your plugs too?
Member #31
PostPosted: Wed Aug 20, 2003 8:14 pm
Switch, you should be using the BPR7ES as the '6' plug is going to be a little too hot for the turbo motor - especially if you up the boost any amount. BPR6ES is what the non-turbo 4G61s and 4G15s use. I use a 0.7mm gap on my 4G61T.
PostPosted: Wed Aug 20, 2003 9:09 pm
Ok - I did use the the bpr73s's for a while but then I changed back...
Next oil change - ill change back to the 7's...
Is 0.7mm gap normal? It seems like a very small gap! I leave them stock at 1.0mm (I think?)
I Run 15psi boost
Mike
Member #31
PostPosted: Thu Aug 21, 2003 12:54 am
0.7-0.8mm is the factory recommended spark plug gap setting for the turbo 4G6x variants. 1.0-1.1mm is the standard for the non-turbo engines.
Chances are you may be getting a small amount of misfire (which may or may not be noticable) at high revs and high boost from the spark event being blown out or otherwise being less than optimal. In any case you should run them at the factory setting.
PostPosted: Thu Aug 21, 2003 1:05 am
Thanks for the info - I will rectify it next oil change when ill be changing back to a td04 too :)
Maybe I shouldve RTFM :)
Member #31
PostPosted: Thu Aug 21, 2003 5:07 am
You will usually notice an increased mileage when changing to the right gap.
Also problems like some light idle surge or a rough running engine will disappear.
The idiot who owned my car before me had plugs w/ 0.7 mm gap (I have a NA car). Changing the gap helped bottom end performance and increased mileage noticeably.
Perhaps you notice the same when setting the gap to 0.7-0.8 mm on your turbo car.
Got rabies?
PostPosted: Thu Aug 21, 2003 8:06 am
what about the wires guys...? :P
Sonny F. Walukow
1999 Toyota RAV4
1990 Honda Accord
1989 Colt GT (Sold)
