It is currently Tue Oct 21, 2025 10:03 am
Post new topic  Reply to topic  [ 39 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Sat Jan 10, 2015 12:47 am
Anyone know the outside diameter of the springs? I got the spacers but they are definitely not wide enough. I was hoping to weld on a bottom washer ahead of pulling it all apart but can't find a diameter. If no one knows I will probably make them 8" and cut them down once I pull it apart...
PostPosted: Sat Jan 10, 2015 8:58 am
You have to consider what size tires you want to run. I had to run coil overs to clear the tires. Had to cut off the stock spring perches to clear anything much bigger than stock.
49 International KB-2
72 Dodge Colt
73 Dodge Colt (Project)
84 GMC K3500
85 Dodge D50 Diesel Swap
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Sat Jan 10, 2015 8:52 pm
For now it all stays stock with just adding the spring lift. Once I work out the right height I will start looking for the perfect springs, struts, wheel and tire combo.
I was hoping someone would know the stock spring diameter so I could weld on the extra perch material to the 5 1/2" wide spacer. That way I can just pull it all drop the spacers in and bolt it back up. I'm trying to minimize the down time by doing the fab work or majority of it before tearing it apart.
PostPosted: Sun Jan 11, 2015 11:40 pm
I Just measured for you my 1989 c53 colt springs are 7" od. Same spring type as dsms. I bet yours are they same too.
instead of welding material to those adjusters you bought why not just weld your original spring "tophats"? Or spring seats? To the bottom of your adjusters. They are exactly the diameter you want and have the nice half moon curved profile that captures the spring perfectly already.....just a thought
i was looking at those parts you bought from speedway...so the bottom plate will go to the spring but what do you intend to connect to the top plate?
The really simple way to do a mcpherson strut lift is to leave the entire assembly alone and just put spacers between the strut mount (the plate with 2 or 3 bolts that comes up throught the holes in your wheelwell in the engine bay) and the underside of the mounting holes in the wheelwell. You would have to press out the strut mount bo,ts and use longer ones of course.
PostPosted: Mon Jan 12, 2015 12:01 am
http://img.photobucket.com/albums/v621/ ... C04591.jpg
basically like this just install this between your strut assembly and your fender/wheel well
maybe you can drill holes etc on those pieces you bought and make them work like this? One thing ive learned too is never be afraid to start again from scratch lol
PostPosted: Mon Jan 12, 2015 10:40 am
Plan was to bolt the top inside the perch, then widen bottom to sit on the spring. The top of the hat sticks through the body with a weird cone piece. Should I just cut that off flush and bolt the lift to that then top to the body?[size]
PostPosted: Mon Jan 12, 2015 12:29 pm
I cant see images if you were trying to post pics. But from what you explained yes thats what i would do. Worst case scenario you would ruin your hats and have to source new ones. But it is already the exact part you could use instead of widening or welding material to your adjusters.
and bolting the adjusters into sounds good to thats what i meant in my above post. As long as the diameter is big enou th for the bolt pattern in your body/wheel well
PostPosted: Mon Jan 12, 2015 3:12 pm
They are wide enough but the bottom plate is only 5.5" so I would need to make it wider to keep the spring in place. I think cutting the hat flush and using it above the entire assembly is a much better idea.
Thanks to all who have helped me with this! I will post pics as soon as I can find the time to do the install...between weather, a flooded back room/garage and my water heater leaking my days off have been consumed! Thanks again for the help and knowledge!
Last edited by AWDColtVista-1992 on Thu Mar 12, 2015 7:46 pm, edited 1 time in total.
PostPosted: Mon Jan 19, 2015 2:56 pm
Tomorrow we lift my Colt! Does anyone know the top hat bolt sizes off hand? 7/16" they look to be but I'm thinking maybe metric now...
PostPosted: Mon Jan 19, 2015 3:08 pm
14mm
PostPosted: Mon Jan 19, 2015 5:59 pm
Thank Thom! I'm guessing 1.0 thread pitch...
PostPosted: Tue Jan 20, 2015 8:00 am
I would lean more towards a 1.25 pitch
PostPosted: Tue Jan 20, 2015 10:41 am
14mm socket but the actual thread size is 10mm 1.25 thread pitch.
PostPosted: Tue Jan 20, 2015 11:44 am
Thanks mirageman! That would have sucked having the wrong hardware. Wish me luck today! Hopefully some pics posted this evening...
PostPosted: Tue Jan 20, 2015 12:14 pm
And of course no one local stocks a fine thread metric tap! Guess Moe has to wait...
