It is currently Mon Jun 03, 2024 7:21 pm
 Post subject: anyone still datalogging
PostPosted: Fri Aug 08, 2014 12:03 pm
I remember back in the day, I had a 90 or 91 talon, and I used mmcd on a palm (can't remember which model), I'd really like to do that again with my 89 DL wagon.
The problem is, I no longer have a computer with a serial port. I have access to machines with windows 7 and one with XP.
I have a Palm IIIX , a sync cradle, and a Palmconnect serial to usb converter. I have all the components I need to make a datalogger cable.
I can't get it to sync on any of the computers I have. So I can't install mmcd on my palm
I started looking into it and found that windows 7 doesn't "play well" with palms I also noticed that most threads with people who successfully got their palms to connect to windows xp machines used drivers that they got directly from palm, which are no longer available since palm sold out to HP.
So, if any of you are datalogging, what are you using?
PostPosted: Fri Aug 08, 2014 1:20 pm
im using either my laptop with win 7.. or my tablet with win 8.(depending on the situation).. but im running jackal from ds-map. its speed density so no maf.. also the dsmlink v3 cable is known to work for the cable.. I have a home made one i made in 05 lol..
PostPosted: Fri Aug 08, 2014 4:31 pm
I still run Palm logger on things just for diagnostics. You can use a USB to serial adapter and it will sync.
49 International KB-2
72 Dodge Colt
73 Dodge Colt (Project)
84 GMC K3500
85 Dodge D50 Diesel Swap
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Fri Aug 08, 2014 5:39 pm
I'm guessing my problem is with the usb serial adapter. Its the actual palm one, I've been reading about people who couldn't get the actual palm usb serial adapter to work, but had good luck with one by belkin
PostPosted: Fri Aug 08, 2014 5:45 pm
I'm using a Belkin, its what I use for ECM Link as well.
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Fri Aug 08, 2014 5:59 pm
Nate,sorry to be a pest, but what model belkin adapter are you using? what operating system on your computer? and what model palm?
PostPosted: Fri Aug 08, 2014 9:32 pm
There are new drivers to make Palm software work on win7. Just went through this to get my logger to work again. I can email you then when I get home if you pm your address.
PostPosted: Fri Aug 08, 2014 10:42 pm
I just looked and its a Keyspan, my bad! I'm running windows 7. I've got an old Palm VX.
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Sat Aug 09, 2014 1:14 am
I'm seeing a lot of them, which model keyspan are you using?
PostPosted: Sat Aug 09, 2014 4:25 am
Just sent you the driver file and MMCD along with a page that has some info on running palm on win7 (with a dl link for palm).
PostPosted: Sat Aug 09, 2014 8:49 am
Keyspan PN: USA-19HS
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Wed Aug 13, 2014 4:08 pm
Ok, got the keyspan you mentioned. Installed the latest drivers from their website. Seems to be installed correctly, says its ready for use.
Installed the palm drivers that Mecha sent me.
I have the latest palm desktop.
When I try to sync, nothing happens on the PC, the palm says its trying to connect, then says it can't.
nothing ever pops up in the device manager during the attempted sync.
bad sync cradle you think?
PostPosted: Wed Aug 13, 2014 6:19 pm
I had a problem on my configuration at one point, think it ended up being my selected port was Serial, but had to be USB (I had 3 to choose from).
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Wed Aug 13, 2014 7:24 pm
thanks Nate.
that was it, had the wrong port selected in the setup :]
PostPosted: Wed Aug 13, 2014 8:59 pm
Awesome!
72 Dodge Colt
84 GMC K3500
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
