due to some unforseen circumstances involving large slicks and a weak differential i am forced to undergo a AWD swap, its not like i want to roll around my garage floor for hours on end but what choice do i have..
pull it in the garage and drop the crossmember..
heres the front motor mount, obviously the old crossmember is in the way of the transfer case so we gotta make a new one.
time to bring out the super expensive engineering tools... a sharpie and some cardboard
after several hours of cutting, test-fitting, removing, grinding, re-installing, etc i ended up with this..
this is the passenger side. my car was missing the tow hook from this side so i had to make my own. the other side is welded to the still intact stock drivers side tow hook.
and we end up with this...
heres what the garage looks like after im done...
more to come..... hopefully
hey man. like what your doing looks good.
im from australia and i found a cyborg crossmember that bolts right in on the standard mounts and fits the transfer case
made my life very easy.
