It is currently Mon Oct 20, 2025 1:50 am
Post new topic  Reply to topic  [ 115 posts ]  Go to page Previous 14 5 6 7 8 Next
PostPosted: Wed Apr 30, 2014 4:25 pm
They're not JDM, you JDM whore. They're from NZ. ;)
PostPosted: Wed Apr 30, 2014 10:18 pm
I knew that! I'm pretty sure they are the same as some euro and Japanese lights though too.
PostPosted: Thu May 01, 2014 9:32 am
They are all the same, but you're still a JDM whore.
PostPosted: Thu May 01, 2014 12:12 pm
Mostly true. I just like having hard-to-find parts and building a car in a way everyone else can reproduce easily.
PostPosted: Thu May 01, 2014 5:15 pm
I know that feel, rare parts are my kryptonite!
PostPosted: Sun May 04, 2014 10:34 pm
Rota slips are as good as sold. Picked up my 4-luggers for this season today. They are rough and will need a full rebuild, but I am confident they will turn out great. They are a lot more period correct for the car anyway. Hope you love them!
PostPosted: Sun May 04, 2014 11:23 pm
Horrible
PostPosted: Mon May 05, 2014 6:38 am
I think if the center were gloss black that would look real nice.
PostPosted: Mon May 05, 2014 11:34 am
Love them. Size and offset?
PostPosted: Mon May 05, 2014 12:26 pm
16x8 +32 will be final offset. Two wheels are 7" wide and I'm using th faces from those to rebuild the 8's. Should be perfect offset on a csm. Maybe a small spacer on the rear to be flush and match the front.
PostPosted: Mon May 05, 2014 2:55 pm
Horrible
Always a hater. These are probably the nicest set of wheels on the board (after refinish). Not everyone can have legit wheels and not knock-offs.
PostPosted: Mon May 05, 2014 3:31 pm
Horrible
I'm only like 50% hater, the other half of me just knows that I have good taste and you don't. :P
PostPosted: Tue May 06, 2014 12:21 am
i'm thinking those will look quite nice on your car, good choice. and a +32 8" rim should fit just right, since i run +25 7" wide, and they're flush in the back. yours will actually be a quarter inch or so further out.
PostPosted: Tue May 06, 2014 3:09 pm
Thanks man! I saw what Debow787 was doing with the XXR's he has on his car, but without being able to put camber in the rear I wasn't comfortable with the amount of poke an 8" wheel would have on a +20 offset. I looked at ebay and found some that were +25, but that is still pushing it on a solid rear axle car, and the fronts would probably need a lot of camber too. Not to mention I can't stand all the knock-offs that are on the market now and how many people run that garbage. Having nice wheels is one of the single most important parts of having a car that is set apart from the rest.
PostPosted: Tue May 06, 2014 3:10 pm
Starting the rebuild process already too. Only had time enough time to dismount the tires and take apart two of the wheels today before work. I disassembled one of the 7" wheels and one of the 8's. The faces of both look to be identical in dimensions (even though they were obviously stamped differently when manufactured) so swapping the good faces onto the 8" barrels shouldn't be a problem.
Hopefully I can get all 6 pulled apart and ready so that I can sandblast them on Thursday. I would like to drop off the hardware to get re-plated on Thursday as well. Then I will just have to find a place to powdercoat them, order new valve stems, and polish the lips up.
