hi guys, i have a few questions about a swap,
what i have:
1992 colt 200gt 1.5L A/T
The donor car:
90 eagle talon tsi 2.0L Awd M/T
The ultimate plan is to swap and make the colt 4g63t powered w/ a manual trans
What do i need from the donor car and what will i need resourced aside from the donor car
ill be pulling the engine, IC and piping, resistor pack, mpi relay, harness w/ ecu, ordering mounts...
You need the entire engine harness, MPI relay, injector resistor pack, ECU. Pretty much anything that plugs into the harness. For mounts you can source some of them from any 92-95 Hyundai Elantra or I make swap mounts and sell them. The trans mount that bolts directly to the trans needs to come from an original turbo colt/mirage o you can mod a dsm one to work. I make adapters as well to plug the dsm engine harness into the csm dash harness.
You wil also need the transmission mount from the frame rail from a 89-92 csm with a manual trans. You also need the clutch pedal and brake pedal from a 89-92 csm with a hydraulic trans along with the master/slave cylinders and any hydraulic lines/brackets. Remember some came with a cable actuated trans and they use a different pedal assembly. Of course you will need a shifter and cables from a csm although with some work I'm sure you can mod the dsm stuff to fit.
I'm actually doing an awd auto swap on my 91 colt so all of my manual stuff will be up for sale shortly once I find time to pull it all out. If you can't find any of this stull locally let me know.
