It is currently Wed Oct 22, 2025 1:23 am
PostPosted: Sat Jul 27, 2013 10:07 pm
I have a 91 dodge colt that i want to put some different wheels on it but there are 4 bolts on my front wheel drums that stop wheels from sucking up.. is there anything i can do about this
1996 Honda civic lx
1994 Ford Ranger
1991 Dodge colt 4G15
PostPosted: Sat Jul 27, 2013 10:57 pm
Not drums sorry.... i ment Rotors
1996 Honda civic lx
1994 Ford Ranger
PostPosted: Sun Jul 28, 2013 1:30 am
What wheels are you trying to put on. You'll have to find wheels that have space necessary for the bolts on that stick out on the hub. Not much else you can do about that.
PostPosted: Sun Jul 28, 2013 10:44 am
I installed universal 4 lug wheels. To fit around the captive rotor bolts I reamed out the unused lug holes a little with a high speed dremmel so they fit over the bolts. Works great.
PostPosted: Sun Jul 28, 2013 11:09 am
well i thought about doing that but we were worried that we would weaken the wheels
1996 Honda civic lx
1994 Ford Ranger
PostPosted: Sun Jul 28, 2013 11:31 am
http://www.4g61t.org/forum/viewtopic.php?f=10&t=9330
There was a bigger list but thats all I could find using the quick search in the archives. The long list has like a full page of stuff that is interchangeable with the colt.
~Ken
'91 Colt - Ongoing work in progress.
http://4g61t.org/forum/viewtopic.php?t=37446
^Check Build Thread^
'82 Chevy El Camino Tow Veh. for my 2012 Skyline Koala 24' Travel Trailer
'06 Chevy Aveo - Daily Driver until Colt is back up and running!
PostPosted: Sun Jul 28, 2013 11:58 am
You can always change to a non-captive brake set up. There are lots of links on here showing how to do such.
49 International KB-2
72 Dodge Colt
73 Dodge Colt (Project)
84 GMC K3500
85 Dodge D50 Diesel Swap
90 Mighty Max V6
89 Mirage Turbo
94 Mighty Max
99 Montero
PostPosted: Sun Jul 28, 2013 7:06 pm
Just buy a cheap 4 lug universal wheel spacer. Not the best way to do it but it works in a pinch.
PostPosted: Sun Jul 28, 2013 8:46 pm
You can also use two headbolt washers per lug, that spaces it out just fine. That's how my colt came when I bought it.
PostPosted: Mon Jul 29, 2013 7:21 pm
I used to run the wheel spacers for that reason. I did still have to grind a little off the heads of the offending bolts too, but not much.
PostPosted: Mon Jul 29, 2013 9:59 pm
Do what the rest of us do when faced with a problem, upgrade :lol:
http://www.4g61t.org/forum/viewtopic.php?f=10&t=24309
PostPosted: Fri Aug 30, 2013 4:24 am
I would invest in a front brake upgrade as well since stock brakes and hub doesn't help at all with aftermarket wheels
PostPosted: Sun Sep 01, 2013 5:10 pm
http://www.4g61t.org/forum/viewtopic.php?f=3&t=24329
4 Lug info
~Ken
