It is currently Tue Oct 21, 2025 10:33 pm
 Post subject: What fuel pump to use
PostPosted: Thu May 16, 2013 10:49 pm
In prosess of swapping 4g63 in 4g15 colt wanna buy bigger fuel pump but don't know what to get that will work in stock setup do I just buy a dsm fuel pump or something specific
PostPosted: Thu May 16, 2013 10:54 pm
DSM ones seem to work pretty well.
PostPosted: Thu May 16, 2013 10:59 pm
Are they all in tank?
PostPosted: Sun May 19, 2013 8:43 pm
yes, you can also use walbro versions. Anything out of tank would be aftermarket, and you would have to remove your old fuel pump anyways. No getting around the tank drop.
4g61t.com
PostPosted: Sun May 19, 2013 9:44 pm
At least you should have a drain bolt in the back of the tank. That will help, versus activating the pump connector on the firewall, assuming the pump still works.
PostPosted: Mon May 20, 2013 4:28 am
turbo 2g will be a direct fit to your stock 4g15 fuel pump assembly
PostPosted: Tue May 21, 2013 6:18 pm
So get 2g Wally not 1g
PostPosted: Wed May 22, 2013 11:21 pm
Get a walbro 255hp with a universal install kit. It's very simple to install. If you can crimp connectors, you can install it.
PostPosted: Fri May 24, 2013 3:00 am
yes, that would be a simple fuel pump swap
