It is currently Wed Oct 22, 2025 10:47 am
PostPosted: Wed Dec 29, 2004 9:08 am
hey guys, i have been searching for a few hours now to no avail.
looking for the wiring diagram for the ecu pinouts on a 1988 ca lancer se with auto trans if that changes anything. cant find it anywhere so far so any help would be great!!!
cheers simon.
90 mirage cyborg(CB lancer gsr hatch), 4g61t, decently modded.
1987 mirage cyborg sedan, 4g61t, 4wd, slow conversion to 4g63t 7 bolt engine.
PostPosted: Thu Dec 30, 2004 11:01 am
Get one for a 1990 1G DSM non-turbo w/ A/T. Just ignore the additional ISC lines, the knock sensor line and the line for the other coil pack. Other than that, it's the same.
Did you get what I just said or didn't I express myself clearly enough (again)? I know, it's a bit confusing the first time.
Got rabies?
PostPosted: Thu Dec 30, 2004 9:10 pm
cheers, does make sense but might need more of a visual help, do you have one of these diagrams? the isc and knock sense lines i wouldnt need to knwo about but the coil packs i do. i am going to install a greddy emanage and need to know the coil pack wiring for the ignition side of it.
PostPosted: Thu Dec 30, 2004 9:13 pm
4g61t Delinquent
yeah i usually need visual help at first :P
I own a CSM.
PostPosted: Thu Dec 30, 2004 9:17 pm
for some reason i usually need this help with women also. heheheh
nah just dont want to stuff it up, just wont work properly and dont wana damage anything while doing it mainly.
PostPosted: Wed Apr 10, 2013 3:21 pm
I hope this isn't to far off topic . I'm also looking for a wiring for my 91 summit auto . I'm wanting to graft in the extra knock sensor wires , coil pack, ignition modual ,resistor box and extra mas wire . I don't really care about the IAC. Would this be an option to buying a harness
PostPosted: Wed Apr 10, 2013 8:36 pm
It's 9 years later.
http://www.4g61t.org/forum/viewtopic.php?f=22&t=9574
