It is currently Mon Jun 03, 2024 2:52 pm
Post new topic  Reply to topic  [ 51 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Tue Jul 24, 2012 10:09 am
It stopped it from leaking in my case
_____________________
1993 single turbo supra
2000 Lexus sc300
2016 ram 1500
PostPosted: Tue Jan 15, 2013 2:58 am
Any more feedback on these fittings, any particular one that works properly?
PostPosted: Tue Jan 15, 2013 4:14 am
anyone have any luck reusing the old fittings and having then crimped onto a new hose?
05 wrx wagon
99 Benz ML 320
94 Audi s4 - sold
PostPosted: Tue Jan 15, 2013 10:06 am
I did not run the car yet... so I can not tell if there a leak.
PostPosted: Wed Jan 16, 2013 2:10 am
Well I have a 1g DSM Aero fuel filter kit with -6 lines, it also has a Earls hard line adapter that looks similar to the ones pictured, I will let you guys know how it works out.
UPDATE: The DSM fuel kit fitting/adapter (earls) does not have an inverted flare seat so it doesn't look like it will seal properly, I'm not even going to try it. As stated before the inverted flare seat is the best way to go, I'll link the proper fittings again..
http://www.3sx.com/store/comersus_viewI ... duct=30271
http://www.ebay.com/itm/170745577579?ss ... 1423.l2649
Still waiting to see how this fitting will work out for Radical Colt but it looks good..
http://www.ebay.com/itm/160696330734?ss ... 1423.l2649
PostPosted: Sat Jan 19, 2013 11:51 am
I get all my stuff here:
http://www.anplumbing.com/
PostPosted: Sat Jan 19, 2013 2:08 pm
Do you have the part # for the fitting to the hard fuel line?
05 wrx wagon
99 Benz ML 320
94 Audi s4 - sold
PostPosted: Sat Jan 19, 2013 2:18 pm
I use Earls 9894DBHERL Female 14x1.5 saginaw to convert from the sending unit hard line right on the tank to -6.
http://www.summitracing.com/parts/ear-9894dbherl
No leaks, no tape, been using it for years.
PostPosted: Sat Jan 19, 2013 3:51 pm
The fitting threads are not designed to hold pressure/fuel from leaking!
The only part of the fitting designed to hold fluid pressure is the tapered seat for the hard line to mate to.
Doing it any other way is, IMHO, asking for trouble. $30 plus shipping or potential fuel leak. :-?
Again, keep in mind your security with a potential fuel leak...
PostPosted: Sun Jan 20, 2013 1:36 am
So an adapter with the inverted flare seat is the fail proof way to go(designed specifically for the use with hard fuel lines).
Adapters such as the Earls are a flat seat design and are not proper for hard fuel lines but have been proven to work.
PostPosted: Fri Mar 01, 2013 7:06 pm
I know this is a little old but I have a waaay cheaper and correct I might add fitting. :axe:
https://www.pegasusautoracing.com/produ ... RecID=7549
PostPosted: Fri Mar 01, 2013 7:09 pm
Nice! That place is only 20 minutes from me. If anyone needs any, I can pick some up locally and save on shipping.
PostPosted: Fri Mar 01, 2013 7:26 pm
Great pick me up two!!!
PostPosted: Fri Apr 19, 2013 11:42 am
Well, I finally attack this piece in my garage. I can understand that parts is not the best. It's fits well, but (like few dudes already says) did not seat properly. The "lips" inside the fitting are similar, but not exactly the same. Infact, the "bleu fitting" cannot be bolted deep enough.
As you see, I had a "good time" to removed the fitting from the assembly line / original rubber... ;)
Let me know if you can't see my pictures (this is my first try with a new web base pictures system).
PostPosted: Fri Apr 19, 2013 11:51 am
I'm not using that fitting at that location which might explain the difference. I have a GVR4 fuel tank and sending unit and I use that blue fitting right on the tank. The fitting on the sending unit spins freely on the tube almost like a brake line fitting.
It looks like that line and end pictured is a solid fitting.
