It is currently Tue Jun 04, 2024 1:18 am
 Post subject: wiring help needed
PostPosted: Thu Nov 29, 2012 9:46 pm
need help with the wiring from the 92 4g63 dsm harness to the 92 wagon.
also need to wire up the trans into the dsm harness.
any help would be greatly appreciated. :)
92 Colt 4G63 16G
92 Talon TSI AWD
93 Talon TSI AWD (son's car)
04 Liberty DD
 Post subject: Re: wiring help needed
PostPosted: Fri Nov 30, 2012 1:21 pm
i need info on this too, still havent got my turbo 1g ecu to work in my 92 1g swapped van
PostPosted: Fri Nov 30, 2012 8:53 pm
lilevo.com/mirage
Dig through the wiring diagrams. If he doesn't have the right van FSMs let me know, I think I have the physical copies.
PostPosted: Sun Dec 02, 2012 6:00 pm
lilevo.com/mirage
checked into lil evo stuff with no luck. found some good info tho.
i believe i have the trans wiring sorted out, just need to wire the 1g harness into the van. i want to keep the a/c and use factory gauge cluster.
thx
92 Colt 4G63 16G
92 Talon TSI AWD
04 Liberty DD
PostPosted: Mon Dec 03, 2012 12:50 am
also if all else fails you can split and trace. Not fun though :(
4g61t.com
PostPosted: Mon Dec 03, 2012 8:08 am
Any diagrams you need in particular? And what year is your van? I will have to check when I get home, but I think I have a couple van FSMs.
PostPosted: Mon Dec 03, 2012 7:01 pm
i need the inside harness diagrams. my wagon is a 92 awd auto
thx.
92 Colt 4G63 16G
92 Talon TSI AWD
04 Liberty DD
PostPosted: Mon Dec 03, 2012 11:49 pm
Those wires are scattered all over the manual. I have a manual for a 94 and have most of the wires figured out but not all of them. I'll dig them out and post them up in the next few days when I find time.
Update:
http://www.4g61t.org/forum/viewtopic.ph ... 55#p298755
