It is currently Mon Jun 03, 2024 11:43 pm
 Post subject: New safari truck!
PostPosted: Thu Sep 27, 2012 12:47 pm
Sold my e30 convertible and stumbled across a Raider for sale in town. It was crap and the lady wanted far too much for it, so I hopped on craigslist and found this gem 6 hours away in Illinois. It has been owned by the same women since 1990 ( its an '88 ) and towed behind a motor home most of its life. They stopped driving it in '05 and held onto it until now when they really needed the space. It is super clean and I got it for a steal. Once I finish cleaning the interior and get the outside detailed I'll grab some better pics.
Notables:
-2.6 carb'd g54 (starion motor)
-5 spd
-Semi-truck style seat suspension on drivers seat (added to passenger seat also by PO)
-Super 1980's interior
Plans:
-31's
-Light rail
-Brush gaurd
-Yakima basket
-4g64 swap down the road (stock motor is garbage)
Seat suspension:
 Post subject: Re: New safari truck!
PostPosted: Thu Sep 27, 2012 6:22 pm
Dude thats sick, I saw one the other day but it wasn't in as good as shape as yours. What are your plans for it?
1991 Plymouth Colt - Project
PostPosted: Thu Sep 27, 2012 7:17 pm
I must admit, that's pretty freakin' cool. How come it's not dumped, stanced, and poked yet?
PostPosted: Thu Sep 27, 2012 7:48 pm
I'm over that. This thing will be a beast. I'll just have a hard time splitting time and funds between this and the Mirage. Both look to be long term keepers for me.
I listed most the the plans in my original post, but here are a couple pics for inspiration and to give you a better idea.
PostPosted: Thu Sep 27, 2012 9:35 pm
Omg! That modded one is sick! Make it look like that lol!
PostPosted: Thu Sep 27, 2012 10:49 pm
Are there any easy straight front axle conversion for these? I have been searching for a samurai/rocky, but if there a way to convert the front to straight axle I would consider this an option. I have always liked these especially the j spec Pajeros's.
PostPosted: Fri Sep 28, 2012 6:01 am
I've been looking at these things too lately. Some even had fuel injection. Nice score!
PostPosted: Fri Sep 28, 2012 9:58 pm
Sick!!
PostPosted: Wed Jan 30, 2013 11:58 pm
the only ones with fuel injection were the 89 V6 models, but the V6 is junk! the 2.6L G54B engine is actually a VERY good engine! I've had a few trucks with that engine and love it!
http://memimage.cardomain.net/member_im ... 3_full.jpg
PostPosted: Thu Jan 31, 2013 8:03 am
CSM O.G.
wow a lot of misinformation in this thread already!
I too have a project Raider (aka Montero), its a blue 89, 2.6 all stock. I am refreshing the motor and then will drive the crap out of it.
The 2.6 engines have gotten a bad reputation over the years for three main reasons:
1) Jet valve heads that cause the heads all sorts of trouble and yes can be "eliminated" with a Jet Valve Elimination Kit, but its best to just get a head that wasn't machined for them in the first place, as its not the valve itself that is the problem, its the combination of the cast steel seat pressed into the head that expands and contracts at a different rate than the aluminum head when the owner overheats it, causing a crack, a coolant leak, and bitchy owners. Repeat this for a few decades and you have some idea why they have the reputation they do.
2) The overcomplicated induction setup. Commonly called a "feedback carb", or a Piece of S**T, it was basically the bastard offspring of carb and fuel injection, with ALL the nightmares you could hope for: excessive vaccuum lines, unnecessary sensors, and a water passage that preheated the carb on those cold mornings, and overheated it on those warm days. The engineer responsible was a seriously evil man. Convert it to a Weber the moment it acts up and you've solved the problem.
3) The balance shafts. Obviously not a problem until they're a problem, just buy the elimination kit.
The 3.0 is as reliable as the owner, if they do the maintenance required before it breaks down from lack of maintenance then they can go -literally- around the world.
The IFS is actually a very solid design, and was continued with very few design changes all the way up to 2002 or later iirc. The later stuff bolts on as an upgrade, as will manual locking hubs if yours doesn't have them. The suspension/differentials/rest of the bolt-on upgrades from the 92-2000 (gen2) hold up to 37's with 4.90 gears and ARB lockers while running the toughest trails around. The only thing they don't do well is flex, live with it, adapt to it, or fab in a potentially-weaker-but-admittedly-flexier solid axle in. I would go with a Drivers-drop Dana 44 from a Jeep Wagoneer, regeared to 4.88 (with 4.90 gears in the rear you won't notice the difference unless you drive it with the center diff locked, while on the pavement, for a while). With stronger axleshafts it will hold up to similar abuse as the rear of the gen1 v6, but nothing like the gen2 sr 9" (3.0 SR's) or the almighty 9.5" (3.5 SR's).
So, in conclusion, do your research before regurgitating information (that you have not personally earned) on the internet.
To the OP, congrats on your purchase. The headlight squirters, the bouncy seat, and the LSD sticker in your doorjamb mean that yours is equipped with the "offroad" package and is very very capable out of the box. Join up on expeditionportal.com in the mitsubishi tech section for people that know way more than I do, and also check out 4x4wire for more mitsu suv tech. Then throw some tires on her and go get dirty!
~joe
PostPosted: Thu Mar 28, 2013 6:00 pm
Wow :o That's clean as hell and the other pic with the off road wheels and lift, you should so do that. I say though is do a 2.3 stroker 4g63 in that bad larry and rip the trails apart :wink: The extra torque will help that truck out pretty well and the fact it's boosted,lol.
