It is currently Tue Oct 21, 2025 10:06 am
PostPosted: Tue Mar 20, 2012 12:56 pm
I have a 1992 Mitubishi Expo and all my motor mounts are shot. I wanted to know if the mounts are similar/same as a 1G DSM, because I was gonna replace them all with polyurethane mounts. Does anyone know? They "look" similar. Thanks!!
Shawn Brown
Boost Boyz Racing
4G63 tube chassis Corolla
PostPosted: Tue Mar 20, 2012 5:09 pm
The transmission mount is the same as a 1g dsm. The rear mount looks more like one from a 3g csm though. I have no idea about the front or the t-belt one. The few 92's that I've seen at the junkyard had a solid cast t-belt mount with no rubber at all on it.
PostPosted: Wed Mar 21, 2012 11:12 pm
On my 92 i used all of the vans motor mounts but the trans is definitely the same and so is the timing belt side, not sure about the others working
PostPosted: Thu Mar 22, 2012 12:27 am
CSM O.G.
I was gonna go poly in my car but found out I would have to buy and mix two different kits, so I got a $20 tube of windows weld and filled them myself. Worked awesome.
PostPosted: Thu Mar 22, 2012 5:34 am
Okay....this sounds like the way I wanna go...but what is windows weld? And where do you get it? This isn't a fancy super horsepower project, I just want the motor to sit still! Thanks!
Shawn Brown
Boost Boyz Racing
PostPosted: Thu Mar 22, 2012 7:47 am
You get it from Napa or most any auto parts store. Its the adhesive they use to seal winshields and once it cures its pretty hard. I would use the two part stuff from McMaster Carr for a cleaner look. You melt the rubber out of your current mounts and reuse the metal sleeve in the middle by cleaning it up with a wire brush. Once the stuff sets up you can drill a hole in in and press the metal sleeve in.
PostPosted: Tue Jul 17, 2012 11:20 am
+1 for Window Weld. the cheapeast and easiest solution. i actually used it on 1 mount which i think i posted pics of in my build thread. i had originally an aftermarket mount but it was just as flimsy as my stock mount that was cracking. i didnt need a whole tube so went to a window place and they hooked it up for the price of a six pack. =) let it cure for as long as you can (id say at least 24-48 hours) because it will take time to harden all the way through.
