It is currently Wed Oct 29, 2025 9:17 pm
 Post subject: 10.6@141
PostPosted: Tue Apr 17, 2012 11:43 pm
The track said I need a full cage But said fruit and banana it and have fun tonight since there was literally only 5 cars running all night
So onto the news..
Runs were done at 37-38psi
11.0@139, 10.9@139, 10.6@141
Last run of the night was on WG spring pressure, 23psi, 11.1@131.
 Post subject: Re: 10.6@141
PostPosted: Wed Apr 18, 2012 12:30 am
http://lilevo.com/lilevo2/videos/gld_2012/10_6_141.mpeg
PostPosted: Wed Apr 18, 2012 12:56 am
Good looooooooord
PostPosted: Wed Apr 18, 2012 1:31 am
Inside cam http://lilevo.com/lilevo2/videos/gld_20 ... decam.mpeg
PostPosted: Wed Apr 18, 2012 8:18 am
Nice! It whooped your ass when you shifted into second. I'd say a cage, seat and harness just so you can drive the thing.
PostPosted: Wed Apr 18, 2012 9:39 am
Are you planning to cage this car, Jason?
PostPosted: Wed Apr 18, 2012 9:46 am
Kinda on the fence.. It's a big project that I've never thought about. No idea where or how to start on it.
PostPosted: Wed Apr 18, 2012 10:15 am
I feel ya. I never want to cage my DSM. Good thing it's slow... :(
PostPosted: Wed Apr 18, 2012 10:30 am
Have a few other issues to fix first. Pumps are running out over 35psi. I have a 255hp in tank and 255 inline both rewired. I might go with that Kenne Bell boost-a-pump and see how much more I can get out of those pumps. Any other upgrade is a mini-project.
Also that weird surging you saw in 2nd gear. Want to upgrade my hot side and maybe throw in better cams than the 272/272s.
Here is another video that shows it better in 3rd gear. Only thing I can think of is compressor surge. It's still the old Ford 5 bolt .63 hot side. I'm WOT when that's happening and the boost is literally surging.
http://lilevo.com/lilevo2/videos/gld_2012/surge.mpeg
PostPosted: Wed Apr 18, 2012 10:48 am
The boost-a-pumps are pretty damn effective. Swapping to a V-band .82 a/r housing would probably make a big difference and give you more power too. The 272's are probably still good for a while.
PostPosted: Thu Apr 19, 2012 2:29 am
Damn on street tires! Nice! Shit is moving.
PostPosted: Thu Apr 19, 2012 11:20 am
If you can do the AWD swap then you can do a cage. Pretty sure you only need a 6 bolt cage so no need for halos over the doors. Definitely look it up in the NHRA rule book. Jegs sells weld-in kits for Fox-body Mustangs that are very cheap and fit 1gs very nicely. I am sure it would fit your sedan.
PostPosted: Thu Apr 19, 2012 11:34 am
Need a 10pt cage for 10.99 or quicker or 135mph+
PostPosted: Thu Apr 19, 2012 1:41 pm
Yeah that stinks. Turns a street car into a race car real quick. Jegs has those real cheap too though!
PostPosted: Thu Apr 19, 2012 7:51 pm
I got my cage from S&W Racecars.. right around $280 shipped for an 8pt but they offer 10pt as well. You take a bunch of measurements of your car and fill out a form and they ship you a pre-bent and cut "kit".
Mine wasn't perfect but it was pretty close. Still required some fitting but for the price I don't think you can beat it.
1990 Colt AWD 8.8
