It is currently Fri Oct 31, 2025 6:30 pm
 Post subject: ISC Driver blow again!
PostPosted: Sat Apr 14, 2012 7:55 am
Hi All,
I have a 91-94 ECU on a 89 Colt turbo harness with 91-94 type of TB with a new ISC from DSMISC that test OK!
My ECU driver IC107 blow again. My wiring is connect like this (diagram from 91-94 manual shop) :
58 Blue(L) wire to pin 1 ISC
59 Yellow wire to pin 3 ISC
67 White wire to pin 6 ISC
68 Black wire to pin 4 ISC
But if I check the diagram from a manual shop of 89 Colt turbo the wiring is as follow:
67 White wire to pin 4 ISC (Instead of 6)
68 Black wire to pin 6 ISC (Instead of 4)
So which of these manual tell the truth? How should I wire my harness?
Could someone tell me the color of the wire at the ecu harness for pin 58-59, 67-68?
And the color of wire at the ISC 1-3, 4-6? With the model/year of is harness?
Colt92t: 12.71@107mph/ 1.8 60' on 22x8x15' slicks, 4g63t, 16g@15psi, FMIC, 3" TBE, K&N, EcmLink
PostPosted: Mon Apr 16, 2012 7:44 pm
More than likley your ISC motor on your throttlebody is blowing the ECU driver...
Change the ISC motor on the throttlebody
Geoff
2013 Genesis 5.0 RSPEC
88 Mazda Turbo II- LSX7
89 2.0 Turbo Colt
13 Ducati 1199 Panigale
PostPosted: Mon Apr 16, 2012 11:54 pm
yea apparently it's like an infectious disease. The ISC will kill the ecu, and a ecu will kill an ISC; making it hard to tech issues.
4g61t.com
PostPosted: Tue Apr 17, 2012 5:33 pm
Your electronics on the 89 turbo colt are the same as a 1990 dsm, and the pins may have changed with 91+ models. The manual for the 89' should be correct.
Good stuff - trucks bring it!
PostPosted: Tue Apr 17, 2012 7:38 pm
Ditch the isc with a full fiav blockoff plate and adjust idle with the bypass screw. I've never had a problem after doing the plate and no more coolant lines or idle issues due to the isc.
PostPosted: Wed Apr 18, 2012 6:32 am
At what rpm did you set your idle?
PostPosted: Wed Apr 18, 2012 3:50 pm
For the warm season, I turn it down as far as it'll go before it stumbles, then add 100 rpm to it. Ends up around 7-800rpm for idle. When it gets cold out (winter), I crank it up to around 900-1000.
